Old 01-31-2012, 08:21 PM   #1
weider1717
Coolant leak, dripping from passenger side rocker panel?
Having trouble seeing where my coolant leak is checked all hoses, what I could of freeze plugs back of intake, radiator etc best I could and nothing but it's dripping from my passenger side rocker panel and the passenger side gas tank shield has coolant splatter on it on the outside...
back of the oil pain is a little wet looking also..any ideas?
weider1717 is offline   Reply With Quote
Old 01-31-2012, 08:38 PM   #2
Eyegore
What Hump?
Eyegore's Avatar
Re: Coolant leak, dripping from passenger side rocker panel?
Possible leak in the heater core, passenger side. Is the floor board wet on the passenger side?
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 01-31-2012, 08:56 PM   #3
weider1717
DING DING DING you nailed it.
carpet isn't really wet but slightly pulled it back at the top and at the edge I can see coolant so it's the heater core...is it easy to replace in these trucks? cars I've had in the past were PITA to change! usually everything on these trucks are easy hopefully this will be too as far as changing a heater core anyway.
Old 01-31-2012, 09:00 PM   #4
Corts60
Just here to tinker
Corts60's Avatar
It is not the easiest job in the world, and might require two people when reassembling, but it could be accomplished within about 2 hours with few cuss words expended.
Old 01-31-2012, 09:40 PM   #5
hopelessredneck
hopelessredneck's Avatar
iv done a couple and the hardest is the bolts below the fan closest to the fender i strongly suggest drop the pass iiner fender and the hole thing should go just fine
hopelessredneck is offline   Reply With Quote
Old 01-31-2012, 09:47 PM   #6
texastruckjunky
texastruckjunky's Avatar
Thats a good idea. That bolt is a P.I.T.A.
Life is to short to drive anything else
texastruckjunky is offline   Reply With Quote
Old 02-01-2012, 12:35 AM   #7
CJ_Chevy
CJ_Chevy's Avatar
i would agree with taking out the inner fender as well, i have to put that bolt in on mine right now actually lol. i would just be careful when you drop the assembly in the cab, if you have a/c and the doors for the hvac are controlled by vacuum, there are 3 or 4 hoses attached that might get damaged. i had to replace one of mine because it was all dried out and cracking.
CJ_Chevy is offline   Reply With Quote
Old 02-01-2012, 10:11 AM   #8
Tucson38
I replaced the core on my '85 a few months ago. I was able to reach the difficult bolt without as much trouble as I anticipated. Removed the puke tank to give me more room to maneuver and used a universal on an extension.
It took me about 6 hours to pull it, take it apart and clean everything, then reassemble and install. This was a first time attempt for me so it can be done in considerably less time with a little experience.
Tucson38 is offline   Reply With Quote
Old 02-01-2012, 02:29 PM   #9
irishman999
irishman999's Avatar
My piece of advice to add to this is buy the most quality heater core you can find. I got a cheapie one from Vatozone or Orileys and the stupid thing exploded while I was on a 1k mile journey during a blizzard. there was literally steam blowing out of the vents, I could not see anything because the windows were fogged up. I sat on the side of the highway for a while letting it cool down and eventually burned my hands with scalding hot coolant. Dont go cheap on this part.
irishman999 is offline   Reply With Quote
Old 02-01-2012, 02:53 PM   #10
85/Silverado
85/Silverado's Avatar
I have a 85 to What is the Puke Tank? I have to change mine to and since I'm doing the radiator to I thought I'd make a weekend out of it lol
Do I have to pull the whole dash out? I saw a Video on Utube but it wasn't the same year.
85/Silverado is offline   Reply With Quote
Old 02-01-2012, 05:36 PM   #11
weider1717
thanks for the info guys think I may have my original one recored.
Old 02-01-2012, 06:13 PM   #12
Keith Seymore
Keith Seymore's Avatar
Originally Posted by 85/Silverado View Post
I have a 85 to What is the Puke Tank? same year.
The coolant surge tank, or overflow tank.
Looks sorta like the windshield washer solvent bottle, only it's got green fluid in it instead of blue.
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-01-2012, 08:15 PM   #13
Tucson38
No, you don't have to pull the dash apart but first step is to remove all the black plastic ductwork from the heater core housing. You'd probably have better access if you pulled the seat out but might not be worth the trouble. It's really not too technical, just some grunt work. Probably a $400 job if you farm it out so you just save about $350 doing it yourself. Keep us posted.
Old 02-01-2012, 10:45 PM   #14
cableguy0
Instead of pulling the inner fender just drill a 1 inch hole to get access to the bolt. Then you can go get a body plug and plug the hole. Its not a bad job. Just the one bolt thats a PITA.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
