01-31-2012, 11:22 PM | #1 |
Hood Fix
The hood on my 78 has started to get that typical bow. I am putting new hinges on it but I was wondering if anyone has tried to straighten one out by themselves. It seems to me even if you keep the hinges well lubed I will still need to put some kind if stiffener on it. Anybody added stiffeners to theirs. Pictures please.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
01-31-2012, 11:42 PM | #2 |
Re: Hood Fix
I have some, not yet installed, but this is for my 76 truck.
LMC had them |
01-31-2012, 11:59 PM | #3 |
Re: Hood Fix
yes i have and you do need it. new hinges will not fix the problem. even if u put a new hood on it will happen again.
and no pic of if you can make them your self to |
02-01-2012, 12:35 AM | #4 |
Re: Hood Fix
After you put your new hood, always push in when pulling the hood down that will also help from it bending.
Life is to short to drive anything else |
02-01-2012, 01:09 AM | #5 |
78 Big10 454
Re: Hood Fix
One of the first things I ever did when I bought my '78 new was to install the hood stiffners.
1978 Chevy SWB C-10 2WD 454/400 |
02-01-2012, 01:33 AM | #6 |
In the Forgotten far North.
Re: Hood Fix
I learned a trick to help keep this from happening with my old 74 c10.
Instead of pulling straight down on the front of the hood, first push the front of the hood BACK (not up) to pre stretch the springs and get the hinges out of their "locked position." THEN you can pull down and close the hood with never any problems. Although your own reach and height of your hood when open are also factors to take into consideration. Learned this trick from my older brother years ago.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
02-01-2012, 08:31 AM | #7 |
Re: Hood Fix
X2 or 3 on the push in then down method and got to keep them lubed. I took and added plug welds on my replacement hood in the vulnerable area prior to paint. Figured it couldn't hurt but still need to be careful
02-01-2012, 07:16 PM | #8 |
Old Heap Driver
Re: Hood Fix
Brand new aftermarket hood, new hinges (NOS), new springs, hood tried to kink the first time I went to close it. I added the stiffeners, problem solved. I have an NOS hood in my shed, the difference between the NOS hood and a China hood is amazing. I kept the China hood because it's painted, pinstriped and fixed with the stiffeners.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
02-01-2012, 07:59 PM | #9 |
Re: Hood Fix
When I got my new Taiwan hood (dual cowl from LMC) I also got new springs, hinges, and stiffeners. A guy in our car club that does show car quality body work ended up convincing me not to put them on. I don't know if this is true but he said that the crumple in the hood was supposed to be a safety feature in a head on wreck. The hood would crumple instead of flying back into the driver. With the stiffeners, he said that any front on collision would send the hood flying back into me because it wouldn't buckle in the middle (the hood stiffeners are thick).
I'm no expert but that's what I was told and why I didn't put them on. New hinges/springs and a lot of grease keeps mine from warping.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
02-02-2012, 09:10 AM | #10 | |
Re: Hood Fix
Myself included.......
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-02-2012, 11:41 AM | #11 | |
78K & 79C Jimmys
Re: Hood Fix
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
02-03-2012, 01:53 AM | #12 |
Re: Hood Fix
Also, spray some WD 40 or lube on hinges. That's why they bend, because hinge gets too stiff.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
