Closed Thread
Old 02-02-2012, 01:56 PM   #1
Rogue_Alphonse
Rogue_Alphonse's Avatar
5 speed question...
The guy told me it's a 5-speed with no low gear... He wants 450 for it (didn't ask if the t-case goes with it) is it worth getting for my stickshift conversion?
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline
Old 02-04-2012, 06:40 PM   #2
silverbullet01
Re: 5 speed question...
if its out of an 88 and up chev the the front shaft is on the opposite side as a square
silverbullet01 is offline
Old 02-04-2012, 07:49 PM   #3
Rogue_Alphonse
I know that, I'd either have to go with an older 208 or preferrably my 205 if it'll bolt up, even if adapters are needed. I still haven't gone and looked at the truck yet, as I'm still in the middle of other things.
Old 02-04-2012, 07:56 PM   #4
Zoomad75
K5Camper
Zoomad75's Avatar
If it's a non-granny 5 speed chances are it's a nv3500 from a 88-up truck.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline
Old 02-04-2012, 08:36 PM   #5
Rogue_Alphonse
I was on the lookout for a 4500, but you think a 3500 is worth it?
Old 02-04-2012, 08:53 PM   #6
silverbullet01
just curious. by why not go with a 4 gear with a 205 case?
Old 02-04-2012, 09:06 PM   #7
Rogue_Alphonse
Actually I have an SM465/NP205 with the crossmember, Blazer shafts, pedal assembly and if I need it floor tunnel. Just need to get a clutch and flywheel assy. for a 6.2 diesel. I personally would rather have more than just three main driving gears, considering it IS a 6.2.
Old 02-04-2012, 09:11 PM   #8
silverbullet01
with 308s it wouldnt be to bad with a 4 gear. top gear in a 4 speed is 1-1. same as top gear in a 3 speed auto.. Posted via Mobile Device
Old 02-04-2012, 09:16 PM   #9
Rogue_Alphonse
It has 3:08's in it now. I found a set of 3:42's in the junkyard last Saturday, and since I couldn't today, next Saturday I may go snatch them up. The thing is lugging at 80mph now, and I have a BAD habit of going 80. Manual downshifting does help though.
I think both the trans and t-case were rebuilt, but I have no idea of the history. I DO know that the 350 that was bolted to it in the 1980 Blazer was a crate [Jasper ugh] engine.
Old 02-04-2012, 09:24 PM   #10
silverbullet01
yeah they labor hard with 308s under 90 ish. my buddy has a 86 1/2 ton 4x4 4 speed with 10 bolts 308 ratio that he has converted into a wrecker with a normal box.and he gets roughly 18 mpg. my dads has 308s with an overdrive. only time he ever uses it is on the highway around 110. Posted via Mobile Device
Old 02-05-2012, 01:02 AM   #11
Rogue_Alphonse
On long highway trips I get 32mpg without a doubt, with A/C and hills trying to drag me down. my average is about 27 all around, running standard tires and that welded rear axle
My issue is the transfer case has too many problems.. I can;t even begin to explain, and the trans leaks like... EVERYWHERE, and I HATE automatics as it is.
If I found a trans I liked, yes I'd sell the Muncie, and as long as I can unbolt JUST the 205 from it to bolt to the new trans, basically yes it would have the adapter housing/shaft thing between. Right now it's sitting on my desk... my other other desk...
Old 02-05-2012, 09:48 AM   #12
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
and thread locked because youve turned it inot a non subscriber for sale thread... next time violations
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline
Closed Thread
