Old 02-03-2012, 08:27 AM   #1
sflem61
long water pump or short
i,m about to install a 90,s model 350 in my 67 swb, I,m trying to decide if i need a short water pump or a long water pump, or will it matter
sflem61 is offline   Reply With Quote
Old 02-03-2012, 08:34 AM   #2
rsavage
rsavage's Avatar
Re: long water pump or short
If you have stock accessory brackets and pulleys from an original era motor you removed that you plan on reinstalling, then I assume you would want the shorter water pump.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 02-03-2012, 08:54 AM   #3
sflem61
I have the bracket that came with engine and i have an set of bracket from a 70,s 350, I just didnt know if i used long water pump if it would push the fan too close to the radiator
Old 02-03-2012, 10:48 AM   #4
rsavage
rsavage's Avatar
Your wiring harness is set up for a driver's side alternator so it makes sense to use original type brackets. If you have or add period PS, you will want your pulleys to line up. If you change to a long water pump you would end up having pulley issues on a stock PS set up. There is not a huge difference in length - short is 5 5/8" deep and long is 7". It will make a difference in how the fan is in relation to the shroud as a long one will put it deeper into the shroud instead of about 1/2 in and 1/2 out as production was.
1961 C1 Corvette
2021 Durango RT 5.7
Old 02-03-2012, 11:17 AM   #5
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
You can shim everything out to match, but I would recommend against it. Its what I had to do on the 71 and the belts make a horrible racket. When I did the Blazer I used a short water pump and everything lined up like it was supposed to.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
