Old 02-03-2012, 08:37 PM   #1
tucsonjwt
C14 or C17 Pedal Rod Booster
I can't get an answer from the parts stores on the proper booster for my 1983 C20.
The options are:
Pedal Rod #C14 - GM Code JB6 Brake (7200 LB.)
Option Codes are Located on the "GM Service Parts Identification" Sticker
Pedal Rod #C17 - GM Code JB7 Brake (8400 LB.)
I don't have a GM Service Parts Identification Sticker, so which one is correct for my truck? How would I tell the difference?
I don't see any markings on the booster or pedal rod itself. I do have a cast iron master cylinder, if that makes any difference.
Thanks.
tucsonjwt is offline   Reply With Quote
Old 02-03-2012, 08:53 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: C14 or C17 Pedal Rod Booster
JB6 = LD 3/4ton
JB7 = HD 3/4ton
JB6 should have 11 5/32" X 2 3/4" drum.
JB7 should have 13" x 2 1/2" drum.
Old 02-03-2012, 09:00 PM   #3
tucsonjwt
Thanks. I guess I will have to pull off a rear wheel tomorrow and measure the drums.
Old 02-04-2012, 04:26 AM   #4
tucsonjwt
I just remembered that I have a floating rear axle. LMC refers to 11" and 11-5/32" brake shoes. Can I determine which shoes I have by looking at the outside of the drum? My VIN has a 4th character "G", which is supposed to be 8001-9000 GVW (VIN tag says 8600 GVW).
Old 02-04-2012, 01:04 PM   #5
tucsonjwt
I finally found it. A very faint stamped "C17" on the pedal rod at the booster end of the rod. What a search.
