02-04-2012, 12:52 AM | #1 |
69 Camaro super cheap build
ok so heres my last car I have and the one that was going to be and my dads build together but it turns out he passed away and i had to buy it from his estate
the car is rough but not as bad as it looks the car was blasted in about 1980 and left in the building without primer so its surface rust all over the car and some rough scale on the drivers quarter but on the good side its all gm and lower miles so its super tight and where its going is a copo build thats gonna be cheap with a bunch of used parts til i get the money to put very nice parts on the car heres some pics of it now with 14x7 wheels and 215/70/14 tires and dog caps but i also have a 69 396 350 hp motor to put in it and im gonna put the ls6 heads and 198 bbc snowflake intake and th400
Explicit Performance "we build dreams" 68 ss 396 chevelle build aka black bettyhttp://67-72chevytrucks.com/vboard/s...d.php?t=504088 68 c10 50th anniversaryhttp://67-72chevytrucks.com/vboard/s...d.php?t=444579 68 camaro build http://67-72chevytrucks.com/vboard/s...=1#post5147614 |
02-04-2012, 12:59 AM | #2 |
Re: 69 Camaro super cheap build
I have a few more pics of the car
Im hoping to get the car completely blasted and in primer on the car but the car is super straight and the floor and trunk pans are awesome so it wont need too much but im looking to put a cowl hood and trunk lid on the car with spoiler and some pics of the motor before I switch the heads out and intake
02-04-2012, 01:07 AM | #3 |
so i got a lot of parts today for a $325
I got motor mount stands, drive shaft, trans cross-member, glass for the 68 camaro, the rear window, window chrome, disc brakes off a 69 camaro, the bbc powersteering pump and brackets gonna pick up the bbc motor mounts tom. also im trying to keep a $1500 budget on this one from the 325 I spent til I can drive it 1175 left
02-04-2012, 07:40 PM | #4 |
Man, I LOVE '69 Camaros. That thing is going to be awesome as a COPO clone. My buddy built an Olympic Gold COPO clone a few years back, and he sold it for gooood money. He's a detail freak, and it was accurate all the way down to the 427/425 horse motor. Not a real COPO, but that meant he could drive it anytime he wanted and not freak out about hurting a priceless musclecar.
Keep posting pictures as you progress!!
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
02-05-2012, 12:32 PM | #5 |
and $60 for sand to sand blast and i got a different car
and note i did this yesterday and the pics before were from friday so primer today and i still have to blast the front fenders and subframe and the rear end but it turned out nicer than i thought it would to be honest so i need to collect some more parts and get some more sand
02-05-2012, 08:17 PM | #6 |
Primer!!!!!!!
and this had been so much work to sand blast the parts with my blasting pot well i got to pull the front clip and blast it and the sub frame and rear end next week o yeah and get the body work done to the shell so a huge step
02-05-2012, 11:17 PM | #7 |
What a difference! Looks like a totally different car.
You did all that blasting with your blast pot? That's crazy!
02-06-2012, 12:29 AM | #8 |
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
02-06-2012, 12:28 AM | #9 |
yeah lol it waqs 7 50lb bags worth and a 200lb pot
it wasnt near as bad as i thought im thinking about getting some slick sand and throwing on a few heavy coats and blocking the car... just the few dent to worry about then i gotta blast the front sheet metal and sub frame... and do inside the trunk so i can put new spatter paint... but this car wont take much I believe the speedo is correct at 26315 cause my nova doors dont shut this nice and the pedals look new and so does the headliner and all the suspension parts... i wanna pull the breaks off to get a better idea... and all the chalk marks are there and ever the coil spring labels!!!!
02-06-2012, 10:12 PM | #10 |
also has anyone ever built on of these cars with a bbc using sbc mounts with power steering? and lso with a manual cross member? what combination do i need to make the engine and th400 trans to fit?
02-07-2012, 03:08 PM | #11 | |
A BBC with SBC frame stands will mount the engine higher in the subframe. There shouldn't be an issue with the power steering. The biggest issue with using SBC stands with a BBC is the hood clearance. You may have to run a flat Corvette intake to clear the hood. Unless you are going to run a cowl hood, then it'll be fine with a standard-height intake. The manual crossmember will work with an auto. Chevy was brilliant in this regard. They used the same trans mount for autos and manuals, and they drilled numerous holes in the subframe legs to accomodate the different transmissions. With the th400, you'll just have to slide the crossmember back to the next set of holes. It's been a long time since I messed with 67-69s. I want another one really bad.
02-07-2012, 12:04 AM | #12 |
born to lose
Love the wheels and caps I need some for my Nova. You should leave it manual and put a rockcrusher or 5 speed in it
_____________________ '67 Chevy Belair Wagon 283 Powerglide '68 Chevy II Nova 2 door 350 TH400 Sold!! '71 Chevy C20 350 TH350 '71 Chevy C10 Burb 350 TH350 stolen totalled gone.... Burb Build http://67-72chevytrucks.com/vboard/s...d.php?t=475155 Nova Build http://67-72chevytrucks.com/vboard/s...d.php?t=498979 Wagon Build http://67-72chevytrucks.com/vboard/s...d.php?t=543052 Not giving a truck. |
02-07-2012, 01:24 AM | #13 |
I have a m20 that i can put in it but then i have to find a bellhousing, clutch, pressure plate, flywheel, longer speedo cable, take the column out for a floor shifter, I do have the transmission and shifter...
we will have to see
02-07-2012, 12:48 PM | #14 |
thats what I am talking about 69 camaro. I see that we are not to far away from one another. Nice job and I know you will be proud once it is complete. If you need anything for your car, let me know as I have 3 69s and 1 68. I might have what you need. Is that an original am or am/fm radio in the car?
I have the front clip off of my 69 convertible and detailing it now. It was not that bad to take off. Good luck with yours. Carl |
02-07-2012, 04:35 PM | #15 |
thanks so much I just wanted know what I have will fit and I am planning on running a 2 in cowl hood I just cant beat the 209.99 price for another AMD hood like on the 68 camaro.... and i finally found pics of copo clone car painted my color
I also gotta clean up my 3.31 posi rear and get it under the car Im really trying to build a daily driver out of this one and prob ride in 2k primer after i get the body blocked til i get money for paint I know mt 68 chevy 2 has sbc mounts and it fits fine and its a non powersteering car and its also got a m21 And i know about the finding one of these hard it was tough i traded a restored 65 belair for my 68 camaro and the camaro was in pieces but hey its what I wanted but heres a pic of what I want all beside I think Ill do the grill black
02-07-2012, 06:24 PM | #16 |
6>8 Plugless........
Sweet build and great work so far! Some day I'd like to have a 67-69 Camaro.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-07-2012, 07:35 PM | #17 |
p p pullin'
great car to start with!....go manual trans all the way
doug |
02-07-2012, 07:46 PM | #18 |
looks solid..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
