Old 02-04-2012, 07:36 PM   #1
NITRO1977
NITRO1977's Avatar
89 resto-mod crew cab short bed
Hello everyone. I have been trolling the board for a while now, and have seen some pretty cool trucks. After selling off my 2001 duramax truck, and my 84 cucv I had a need for another truck. Enter a 1989 chevy c2500 3+3. I have always wanted a 4wd crew cab but was unable to find one in my budget. So I decided to buy the 2wd and convert it to 4wd and a short wheelbase. I removed the rear bed.....and rear frame . The axles were some that I had picked up from a friend. Front is a 78 ford hp60 stuffed with 4.56 gears, 35spline dana 70 stubs, dodge knuckles, chevy outers, warn premiums, and the bottom has been shaved. The rear is a van 14 bolt with 4.56's, a detroit, and custom disc brakes in the form of dana 60 calipers and brackets.
89 2wd crew converted to shortbed 4wd, cummins swap (in progress), 63" rears w/shackle flip, 52" fronts, hp dana 60 front w/ 35spline outers/ high steer, van width 14 bolt rear w/ dana 60 calipers, brackets, rotors, 4.56, and detroit.
NITRO1977 is offline   Reply With Quote
Old 02-04-2012, 07:41 PM   #2
NITRO1977
NITRO1977's Avatar
Re: 89 resto-mod crew cab short bed
Rear suspension is comprised of 63" leafs with a shackle flip. Front is a custom 52" conversion (I will be replacing the crappy front springs with new ones). I recently aquired a 93 5.9 cummins with 90k on it to fill the engine bay . The plan is to build a 47rh transmission and put a late model transfer case behind it.
Old 02-04-2012, 07:42 PM   #3
NITRO1977
NITRO1977's Avatar
Pic of the front hangers I built.
Old 02-04-2012, 08:34 PM   #4
yousesteers
Looks good I have 4:56 in my 84 with the cummins/NV4500 and it needs another overdrive will run about 60mph
Clint Youse
Paris, MO
1984 Chevrolet 3+3 K30 with Cummins
1966 IH Scout has been a work in progress for 16 yrs
yousesteers is offline   Reply With Quote
Old 02-04-2012, 08:40 PM   #5
NITRO1977
NITRO1977's Avatar
What size tires are you running?
Old 02-05-2012, 11:42 AM   #6
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Would like to see more of this truck.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 02-05-2012, 02:12 PM   #7
Devillusion
Devillusion's Avatar
subscribed.....interesting.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 02-05-2012, 07:32 PM   #8
rocking chevy
rocking chevy's Avatar
looks good, how much lift do you have?
rocking chevy is offline   Reply With Quote
Old 02-05-2012, 08:00 PM   #9
NITRO1977
NITRO1977's Avatar
I think its about 5" right now. It will probably end up with 4" once the diesel goes in, and the truck is fully dressed.
Old 02-07-2012, 09:44 PM   #10
NITRO1977
NITRO1977's Avatar
Ok...not any physical progress to report, but I think I have most of my info on the transmission. I still need to decide which converter I am going to run though. I am going to try to get the old engine out this weekend if I have time after working on the pull truck. Does anybody know what would be a good durable frame coating that will hold up to the corrosive environment here in maine? I have heard good and bad about por15. I would like it to hold up well, but not cost a fortune....if at all possible. More pics too come soon.
Old 02-07-2012, 10:24 PM   #11
AntiGov
AntiGov's Avatar
check out RUST BULLET , im starting to use this now on my crew, sprayed under side of bed while off for paint, also had a guy sand blast my battery trays and some misc other stuff and i sprayed those today. it does not require top coat for uv protection but im going to finish coat in a satin black as the rust bullet is silver color.....from what i researched the rust bullet requires less prep and holds up better than por15.......ordered mine from summit...
88 3+3 454 400 205 410 drw to srw still in pieces
90 3+3 350 400 205 410 srw
84 1/2 ton lb 6.2 4x4 parts truck
AntiGov is offline   Reply With Quote
Old 02-07-2012, 09:49 PM   #12
NITRO1977
NITRO1977's Avatar
Heres whats been keeping me busy this week....06 duramax. I installed head studs, turbo, injectors, cp3, and a bunch of other cool parts.
Old 02-08-2012, 03:07 AM   #13
joe231
joe231's Avatar
Nice start!!
More info and pics on the 14 bolt with Dana 60 brackets and calipers please?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 02-08-2012, 09:19 PM   #14
NITRO1977
NITRO1977's Avatar
The 14 bolt brakes are pretty simple..They use factory dana 60 front calipers and brackets. My friend made up a couple of weld on rings for the housing that accept the caliper brackets. The rotors are also dana 60 front.
Old 02-08-2012, 10:01 PM   #15
Corts60
Just here to tinker
Corts60's Avatar
Do you have pics/info on how the duramax is bolted up?
Old 02-08-2012, 10:20 PM   #16
joe231
joe231's Avatar
I thin the D-Max is in a newer truck, I'm guessing the '01 in his sig...
CHEVY ONLY
Old 02-09-2012, 09:08 PM   #17
NITRO1977
NITRO1977's Avatar
The duramax isn't in my truck..its just a customers vehicle. I wish it was in mine though.....way out of my price range right now.
Old 02-09-2012, 09:13 PM   #18
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice project! On the torque converter, I'd go with a DPC. I can get you a price on one if you like. Also, nice job on the spring hangers. Very nice.
Ryan
1969 Chevy milk truck
Old 02-11-2012, 04:33 PM   #19
STOCKISH
STOCKISH's Avatar
Looks cool man, any progress?
--Josh
Old 02-11-2012, 04:55 PM   #20
yjheep
Looks good, im building a similar truck but after 8 months of looking for a good short bed i gave up and went long bed. I thought i would share some info with you on amount of sag with the cummins, Im running heavy lift springs in the front and i lost almost 2 inches in the front with the cummins over the 454. i built custom hangers and shackles to correct it. look for my build thread to be up in the next few days. im about half way into it.
yjheep is offline   Reply With Quote
Old 02-11-2012, 06:43 PM   #21
yousesteers
I am running 265/75/16 right now I lost about 1/2 inch of hiegth from the 350 to the cummins and my springs need replaced.
Clint Youse
Paris, MO
Old 02-11-2012, 09:24 PM   #22
NITRO1977
NITRO1977's Avatar
Not much progress lately, but that will change this week. I just finished up 3 duramax jobs, and i will have a little breather. I actually got rid of the front hubs that were on the truck a little while back, and I am in the shop right now putting my new ones together. Hopefully I can get them on the truck tomorrow so it is rolling again. Next I am going to pull the front clip off, and yank the motor/tranny so I can mock up the engine. Pics coming soon.....Thanks for all the comments.
Jason
Old 02-11-2012, 09:32 PM   #23
NITRO1977
NITRO1977's Avatar
Teaser pic.....
Old 02-12-2012, 05:21 PM   #24
NITRO1977
NITRO1977's Avatar
Man it is cold out.......gotta love single digits. Anyway, I braved the cold today and got my hubs back on. The truck will be back in the garage tomorrow for the nose dissassembly.
Old 02-13-2012, 12:55 PM   #25
NITRO1977
NITRO1977's Avatar
Its back in the shop Nose is pulled, wiring disconnected, and the engine/ tranny will be out today. I'm hoping to get the engine crossmember done tomorrow. After that I need to pull the cab so I can finish up the frame, and send it out for blasting.
