Steering Ratio?
Ready to order new power steering box but not really sure what ratio I need.
69 SWB Fleet/72 running gear Currently under frame-off 67 SWB Stepper smallwindow |
Active Member
![]() Join Date: Jul 2007
Re: Steering Ratio?
There's a few ratios available but I found that the quick ratio 2.5 turns of the steering wheel lock to lock made my 68 GMC a little squirrely on the highway. I swapped to standard ratio -app 3.5-3.75 turns lock to lock -and it handles better on the highway.
However, if you do a lot of in town driving then you may want the quicker ratios. |
Re: Steering Ratio?
Thanks but what I don't understand is the 16:1, 14:1, or 12:1. Which one of those is the factory style or which one is the quick?
#4 | |
Active Member
Re: Steering Ratio?
The steering ratio is a number of degrees that the steering wheel must be turned to pivot the front wheels 1 degree. The higher the steering ratio (30:1 for example). the easier it is to steer the vehicle, all other things being equal. However, the higher steering ratio, the more the steering wheel has to be turned to achieve steering. With a 30:1 steering ratio, the steering wheel must turn 30 degrees to pivot the front wheels 1 degree. Actual steering ratio varies greatly, depending on the type of vehicle and type of operation. High steering ratios are often catted stow steering because the steering wheel has to be turned many degrees to produce a small steering effect. Low steering ratios, called fast or quick steering require much less steering wheel movement to produce the desired steering effect. Forgot to add> I would stick with the lower (quick) ratios if you will drive mostly in town. Get the middle range ratios if mostly highway. |
Re: Steering Ratio?
Wow thanks! Makes sense now
![]() Join Date: Jan 2006
Re: Steering Ratio?
I like this one variable ratio, best of both worlds. It is a bolt on but hoses and pump might have to be changed, depends on what engine your running. The guys at ARG are happy to answer emails. http://www.summitracing.com/parts/AG...UP&prefilter=1
1972 GMC 'Project Red' Long Road Ahead |
