Drop spindle question
I found a pair of belltech 2" spindles I can get for pretty cheap. They were bought for an 80's c-10 but that's all the guy can remember. He wasn't able to find any stamping or numbers on them.
Is there any way to see what width rotor/caliper they fit without it being a coin toss? Thanks ![]()
riding... just riding....... |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Drop spindle question
Do they have a "3100" or a "3200" cast into them?
Where would I look? He said he didn't see any numbers (I was going to just contact belltech.) Thanks
It's usually cast on the lower "leg" of the spindle.
(below the spindle itself) Can you post a picture of them?
If you have 1-1/4" rotors, you can easily modify the spindles if they are for 1" rotors. You have to grind down the area where the caliper bolts. I did a pair with an electric hand grinder, took my time so everything was still flush.
#6 | |
The 1" rotors take a different inner bearing, I believe. (one of the two bearings is a different part number than the 1-1/4" rotor)
#7 | |
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
