Old 04-29-2003, 06:34 PM   #1
WHYBYNU
WHYBYNU when old will do
WHYBYNU's Avatar
Help please...
My truck has a miss in it at around 2500-3000 RPM. I've checked the timing it seems fine plugs&wires are in good shape. The trucks runs fine if you put your foot in it but will miss if you slowly climb up to speed. I pulled the vac advan. line off and the motor speed goes up so
71 Cheyenne super
2 tone green and white
ZZ6 - Th350
4/6 drop
20x8.5 / 20x10 Billet Specialties
WHYBYNU is offline   Reply With Quote
Old 04-29-2003, 06:37 PM   #2
WHYBYNU
WHYBYNU's Avatar
Sorry I screwed the last part up,not sure what to check next . Any ideals guys? (350 w/stock HEI)
THANKS IN ADVANCE
John
71 Cheyenne super
ZZ6 - Th350
4/6 drop
Old 04-29-2003, 06:52 PM   #3
Southpa
Southpa's Avatar
Have a look for any damage in the dist. cap. Any backfiring out the intake when under load? Also, timing chain could have jumped a link or be stretched.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 04-29-2003, 06:55 PM   #4
bigjimzlll
bigjimzlll's Avatar
Does the rpm go up with the vacuum advance disconected and the line plugged? Which port do you have the vacuum advance hooked to? A couple of things to look at...pull the cap and suck on the vacuum line..it should move the plate..if it dosent look and see if the plate is stuck. If its not stuck, the cannister might be bad/have a hole in it/stuck. The rpm range that you have the miss indicates it is probably in the vacuum advance
Just thought of something else..if the vacuum advance is working correctly, it could be the wire on the pickup thats slightly broken, and when the advance moves the plate it partially breaks the connection.
Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 04-29-2003, 09:30 PM   #5
lngbed71
Nothing fits but the oil
lngbed71's Avatar
Do you have the 84 and up HEI with computer controls needed?
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 04-30-2003, 07:47 AM   #6
72K10
my nickel's on a bad plug wire. I had the same thing, and it turned out to be one slightly baked plug wire that was impeding spark at higher rpms.
RLTW
70C10
72K10
72K10 Cheyenne
72C10 Cheyenne Super
72K10 is offline   Reply With Quote
