Old 02-08-2012, 05:11 AM   #1
sanford66
sanford66's Avatar
WTB Short shift Lever Handle
I need a short shift lever handle that will work in my 72. I'm changing my steering wheel to a smaller aftermarket wheel and need the shorter shift lever. It is a tilt column. I saw on here that the van columns had the shorter levers, if so this is what i'm looking for. Thanks. Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 02-08-2012, 05:40 AM   #2
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
Re: WTB Short shift Lever Handle
I should have an extra.. I will get back with you later this morning.
Duane
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline   Reply With Quote
Old 02-08-2012, 07:21 AM   #3
sanford66
sanford66's Avatar
That would be great Duane. If you find one post up some pics. I need one with good chrome and no wear on the base where it mounts into the steering column. In other words a nice tight shifter handle. Thanks for checking for me. Joseph
