02-08-2012, 09:09 AM | #1 |
igntition switch repalcement?
hey guys i went out to crank up the old 79 4x4 the other day and my ignition switch made a terrable grinding noise and now the switch dosent do enything how hard is it to replace the igniton switch on a 79 chevy with tilt steering?
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin 79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s 81 mercedes 300d 25 MPG 77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded" 73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091 '77 chevy trucks. built to stay tough. life is short build a hot rod |
02-08-2012, 09:35 AM | #2 |
Robert Olson Transport
Re: igntition switch repalcement?
they key swithc is pretty simple as long as you have a gear puller and the tool to compress the cover thats underneath the wheel... both can be rented at autozone for free tho
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
02-08-2012, 09:49 AM | #3 |
awsome thats good to hear i might try to tackle that soon
02-08-2012, 10:36 AM | #4 |
Are you talking about replacing the key/lock cylinder or the ignition switch itself (located behind the dash on the column)
I've only done the ignition switch and not the key, and I've never done it with the column on the truck, but replacing the ignition switch assembly is really easy - unhook the connectors, unbolt two screws and the assembly comes right out. May be a tight fit if your hands are too big (mine are relatively small). The ignition switches are different for tilt wheel vs. non-tilt (the rod travel is reversed).
-Steve 1980 GMC C15 Sierra LWB Dark Carmine Red/Carmine Int Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011) Now: 5.3/4L60E, 2.73 12-bolt open rear |
