Old 02-08-2012, 11:00 PM   #1
jagee
Need help with an upper radiator hose
I've read every thread I can about upper radiator hoses but can't find my answer. I'm putting the 383 back in my buddy's 62 and need to find an upper radiator hose.
The radiator outlet is 1 3/4" and is on the driver's side and the thermostat housing is 1 1/2". He's wanting to use a molded hose so he can put the stainless braid over it.
Every part number that I have seen on here is only 1 1/2" on both ends. Can anybody help me find a hose?
jagee is offline   Reply With Quote
Old 02-08-2012, 11:14 PM   #2
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Re: Need help with an upper radiator hose
Is this the stock radiator for the '62?
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 02-09-2012, 12:15 AM   #3
jagee
I honestly don't know. It looks like it is but we don't know much about the history of the truck. I've looked up stock radiator hoses and they are all 1 1/2" which makes me think that his aftermarket. But it still looks factory.
Old 02-09-2012, 02:46 AM   #4
dracko
dracko's Avatar
These reducers should do the trick.
http://www.goodyearep.com/ProductsDetail.aspx?id=15008
dracko is offline   Reply With Quote
Old 02-09-2012, 11:47 AM   #5
Rich 5150 69
Rich 5150 69's Avatar
The molded hose for the top are getting difficult to find, LMC shows they have it ...? so its a crap shoot, the molded hose fits `64 to `72 sm and BB although the BB uses a 1 3/4 thermostat housing, they do interchange with the small block, bolt pattern is the same. Suggest go to a small parts house locally and see if they have one on there shelf. The alternative is to use a steel rad hose with rubber connectors, that was the factory design in `64 I believe.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 02-09-2012, 12:22 PM   #6
T Smith
T Smith's Avatar
I'm in the same boat, the molded hoses are 1 1/2" on each end and the NAPA replacement radiator I bought has a 1 3/4" outlet compared to the 1 1/2" stock radiator outlet so I'm having to run a flex hose. NAPA has the molded upper but it's 1 1/2" on each end. Doesn't make sense that their replacement radiator has the oversize outlet, maybe that's what your buddy's radiator is as well?
T Smith is offline   Reply With Quote
Old 02-09-2012, 01:00 PM   #7
MisterC
MisterC's Avatar
Good luck. After a week long exhaustive search and some great help from board members, I went with the flex version that has the proper size on each end.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 02-09-2012, 02:14 PM   #8
jagee
We're thinking about going with this: http://www.summitracing.com/parts/SPE-5922/
The longest they have is 22". The motor is not in the truck yet so I can't measure how long I need. Do you guys think it would be long enough?
Old 02-09-2012, 02:18 PM   #9
Rich 5150 69
I just went out and measured mine.... 22 inches will work.
Old 02-09-2012, 05:48 PM   #10
purebred
I have been using a 22 inch, 1 1/2 inch both ends on my 65 for years now and never had a problem with the thermostat housing leaking. Seems like 50.00 bucks for a radiator hose is a little steep, paid 7.00 dollars for mine at auto zone.
purebred is offline   Reply With Quote
Old 02-09-2012, 08:55 PM   #11
jagee
I'm not worried about the thermostat housing leaking. I'm worried about it fitting on the radiator because it is 1 3/4".
Old 02-10-2012, 06:47 AM   #12
purebred
HUMM, My radiator is 1 1/2 inch and thermostat is 1 1/4, Never seen a smaller inlet on a v-8 radiator, what sizes do you have?
Old 02-10-2012, 02:10 PM   #13
jagee
1 3/4" at radiator and 1 1/2" at thermostat.
