02-09-2012, 06:19 PM | #1 |
homemade intake for inline 6
has anyone ever made a homemade intake manifold of anykind i am toying with the idea of making either a dual carb or 4bbl intake for my 250 inline prob do it for way cheaper than you can buy one. so any tips or pics would be appreciated.
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
02-09-2012, 06:23 PM | #2 |
Re: homemade intake for inline 6
http://www.inliners.org
All inlines, all the time. click on the bulletin board and the tech tips. -W |
02-09-2012, 08:58 PM | #3 |
My dad did , oh in 1958 or so , he capped the middle carb port and my grandfather brazed 2 one barrel mounts on either side of the center one... then he added another exit to the manifold....
02-09-2012, 09:04 PM | #4 |
I am thinking simple like a tube with capped ends and 2 carbs on top with with tube runners going down to the engine head. Kinda going for the old school home built back yard hot rod look. also thought about putting some sort of velocity stacks on the carbs and either just barely sticking them out the hood or put a 68 camaro louver on the hood just above the carbs.
02-09-2012, 10:25 PM | #5 |
HOW long until spring??
I had a stock 250 intake that somebody welded on a 1/2 plate that was to able to adapt things to a 4412 Holley for circle track use.
I sold it on E-bay and it went somewhere in Texas. Must not have been you that bought it.... I bought an Offenhauser intake off E-bay for around 130 bucks... I did not think I wanted to mess around with a home built thing if I could find an real Offy. I am storing and hanging on to a Clifford 4 barrel intake if I ever want a build another six .(6=8 ya know) I am presently using the Offy and a Holley 7448 -350 CFM and having no problems. good luck !!!
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" |
02-09-2012, 10:38 PM | #6 |
Amazing what pictures we have stored on the computer and should clean out. I called this day back in 2010 "Manifold Christmas". A friend of my father in law was cleaning out his garage and had all these manifolds from the old super six racecar days == They went to the newer V-6 engines in the racecar now, so I was more than happy to help him out!!
02-10-2012, 12:28 AM | #7 |
I'll never forget that old 1951 chevy pickup with the bottom bases of 2 1-bbl carbs "brazed" upside down on either end of the stock intake. The 3 carb'd intake looked so cool and so neat a way to bolt the 2 extras on. Owner assured me it ran stronger with single exhaust than same setup with his also-homemade split exhaust manifold. Also said the split manifold helped power a lot, but not as much as the 3 carbs--either one, but not both! Also claimed 3 carbs increased gas mileage, but even by itself, the split m'fold cut mileage! Go figure.
sam |
02-10-2012, 01:48 AM | #8 |
i think i am just going to do a square box where the carb will bolt down then round tube intake runners going down to the intake ports on the head prob powder coat it and call it a day would really like to make it from aluminum if i could get the metal for cheap or free. being as i am doing this on a budget
02-10-2012, 02:07 AM | #9 |
you are Krazy! unless you are talking about building a racing engine.
Thats a lot of work when the aluminum Offy's are plentiful and proven. If you proceed, also look at Santucci's book. Whatever you do, don't forget to run water heat to the manifold floor for street use.
292 + TKO500 |
02-10-2012, 02:47 AM | #10 |
[QUOTE=Heater63;5178594]you are Krazy! QUOTE]
Hence the name lol. well i dont plan on building a race engine thats for sure or atleast right now. I have been reading and researching all day and figured it would be a fun side project using my truck as the test mule. I have been putting pencil to paper and drawing up different ideas and setups. Honestly doesnt look really that hard if you have a welder, a way to cut metal and a good imagination. I am going for a rugged homemade look but at the same time not to crude. I did stray for about an hour looking at turbos and what not but decided to focus on the project at hand. i think i am going to attempt a 4 barrel intake first mostly cause i have a 4 barrel carb laying around lol. When i do start to fab stuff up i will take lots of pics and show all you guys how krazy i really am lol
02-10-2012, 07:33 PM | #11 | |
X2 on Leo Santucci's box -- Crazy things that can be done with a inline 6
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 02-10-2012 at 07:33 PM. Reason: added text |
02-11-2012, 01:29 AM | #12 | |
292 + TKO500 |
02-10-2012, 02:11 AM | #13 |
I made one from steel for some motorcycle fuel injection throttle bodies, could work the same for carbs.
I had the flange cut on a plasma table using the stock gasket as a pattern, added coolant piping (the factory manifold had coolant passages). Attached the throttle bodies with silicone tubing but if you wants side/downdrafts you could just put a mounting flange. Problem I had was the steel was an amazing conductor of heat from the head and heat soaked the throttles on long trips. If I did it again I would use aluminum as the material. otherwise it sounded amazing and the 1/4 turn throttle was just asinine fun hooked up to a pedal, like an on off switch for an angry monster.
02-10-2012, 12:02 PM | #14 | |
02-10-2012, 12:50 PM | #15 |
meowMEOWmeowMEOW
I'm guessing its a F*rd 2.3, they made that valve cover for Mazda B2200 pickups.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
02-10-2012, 02:52 PM | #16 | |
And vernski, he asked for homemade intakes of any kind. To make it a 6 you would just add two barrels. But I will say that my daily 4 cylinder (not the pictured engine) is 263hp and 280 torque, no extra cylinders needed Posted via Mobile Device
02-11-2012, 03:10 AM | #17 | |
02-11-2012, 06:29 AM | #18 | |
and my daily is a production car, a mazda speed 3. its like driving a sledgehammer.
02-11-2012, 06:46 PM | #19 |
meowMEOWmeowMEOW
Damn, I was close.
