Old 02-10-2012, 01:55 PM   #1
Old_1965_Gmc
want to lower my rear leaf any good advice
Ok I want to lower my rear leaf springs I've been in the search for any info but haven't had any luck so far and good advice opations tricks and tip any good info is welcome thatnk,Marco
Old_1965_Gmc is offline   Reply With Quote
Old 02-10-2012, 03:07 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: want to lower my rear leaf any good advice
What year truck?
1/2 ton?
3/4 ton?
2wd?
Keith
Convert to disc brakes.
Old 02-10-2012, 05:36 PM   #3
Old_1965_Gmc
65 gmc 3/4 ton 2wd 305 v6 longbed and 5lug disk/drum
Old 02-10-2012, 06:56 PM   #4
lolife99
lolife99's Avatar
PerformanceOnline sells 1/2-ton and 3/4-ton drop leaf springs,... but list tham as 66-87 models.
http://www.performanceonline.com/196...AF-SPRING-SET/
I wonder what the difference between 65 and 66 is?
Keith
Old 02-10-2012, 05:38 PM   #5
killerb68
Depends on how much you want to drop it...1-2 inches you can get with extended shackles...3-5 you can get different leaf springs....I'm gonna flip my rear axle to the top of my springs to obtain a 6-7 inch drop on my 66 GMC
killerb68 is offline   Reply With Quote
Old 02-10-2012, 05:39 PM   #6
killerb68
Old 02-11-2012, 04:20 AM   #7
57truckguy
I put my axle on top of my springs and removed every other one leaving 4 or 7 leafs for a 6 to 7 inch drop.in the rear. Front put a 89 dodge Dakota front end for a 6 inch drop using the 4 cyclinder coil springs. Works great, just really need to put a knotch in the rear about three inches for additional axle travel as it does hit the frame once in a while.
57truckguy is offline   Reply With Quote
Old 02-11-2012, 07:46 AM   #8
Old_1965_Gmc
Canu show me some pics on the result u guy got going on
