Old 02-10-2012, 10:14 PM   #1
gofastnut
gofastnut's Avatar
"Old Brownie" build
Hi,
Been following/lurking for a couple years before I joined last year. I'm hoping starting this thread will help keep me motivated. Looking at all these builds has given me the "sickness"!
65 shortie step side
I 6 w/ 3 on the tree
No AC, standard heater
Been in the family since Day One. Great Grandpa bought it, sold it to his son-in-law, who sold it to his son-in-law(my dad), who let it sit. And sit. And sit
Pretty much bone stock with the exception of the 8-track and larger radiator my dad Okie'd in about 94.
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 02-10-2012, 10:19 PM   #2
gofastnut
gofastnut's Avatar
Re: "Old Brownie" build
Here she is in all her glory.
Jeff
C-10 Club
Old 02-10-2012, 10:25 PM   #3
gofastnut
gofastnut's Avatar
Few more pics of her...
Jeff
C-10 Club
Old 02-10-2012, 10:27 PM   #4
gofastnut
gofastnut's Avatar
Was gonna cut a coil off each rear on Monday, but then I found this
Jeff
C-10 Club
Old 02-10-2012, 10:31 PM   #5
gofastnut
gofastnut's Avatar
Oh Yeah!! I used to go with Dad and Grandpa to cut wood. It's only natural there would be overload springs! Especially the way we'd pile up scrub oak in the bed, sometimes up to the bottom of the window!!
So, the clamps came off pretty easy and now I have some good used old school overloads I gotta do something with.
Then, I looked, really looked at the spare tire...
Aww man, this is a bias ply radial! Probly older'n me!!!
Jeff
C-10 Club
Old 02-10-2012, 10:35 PM   #6
gofastnut
gofastnut's Avatar
A little help from my "buddy" (5 yr old son) and the spare and bracket were off!
Man, how old IS this tire? Anyways, here's the overload/helper springs too.
Jeff
C-10 Club
Old 04-05-2013, 09:05 PM   #7
jayoldschool
Moderator
Hmm, your air cleaner intake has been cut, like mine. This is the only other one I have seen like this. Anyone have an idea why this was done?
jayoldschool is offline   Reply With Quote
Old 02-11-2012, 04:43 AM   #8
C@rnut001
Your truck looks like a nice solid truck to start with. It is even greater that it has been in your family. I loved the overload springs...you knew that it was being worked when it was younger... Anyway, thanks for sharing your rebuild of the old girl with us. Looks like the spare has not been used in a long time...
C@rnut001 is offline   Reply With Quote
Old 02-11-2012, 12:11 PM   #9
gofastnut
gofastnut's Avatar
Thanks for the kind words, guys. My build will be slow, that's all time and money will allow at this point.
Oh, expecting to hear some cr@p for the mismatched wheels. Dad took the fronts off because one valve stem was leaking and he was too cheap to fix it.....So....I've got some 15x10 centerlines for sale if anyone's interested. (and yes, that part should be on the WTS page!)
Jeff
C-10 Club
Old 02-11-2012, 03:32 PM   #10
gofastnut
gofastnut's Avatar
Dang! the front end I found is 8-lug, cr@P!!
Jeff
C-10 Club
Old 02-11-2012, 10:55 PM   #11
Jeff La
Good luck on the build, will follow along
Jeff La is offline   Reply With Quote
Old 02-13-2012, 09:22 PM   #12
gofastnut
gofastnut's Avatar
So, I had to service my dad's pressure washer, but I got to use it. I'm not sure if this is worth 2 hrs of work or not. I know C4metalworks used oven cleaner to take some of his old paint off, can anybody fill me in on that procedure?
Oh, now that some of the paint and couple pcs of bondo are gone...I see holes!!
I knew the front corners of both doors were rotted, and the rear corner of both fenders, but didn't know about the driver's side lower sill panel. Oh well, it's only time and money!
Jeff
C-10 Club
Old 02-14-2012, 12:03 AM   #13
C@rnut001
You may have found some holes, but in the long run it will be better to know what you have under there. It is looking good. Keep working on it. I think the oven cleaner method is coupled with elbow grease and scotch brite pads.
Old 02-14-2012, 02:14 AM   #14
gofastnut
gofastnut's Avatar
Thanks C@arnut. I searched on the forum, but didn't find anything laid out in steps. I did notice that leaving the oven cleaner on the black primer(over the brown, over the gray, over the red) for about 30 seconds softened it up enough some.
Any and all advice is really appreciated, after all, seeing you guys and gals with your trucks is what made me start on mine!
Thanks again.
Jeff
C-10 Club
Old 03-05-2012, 04:42 PM   #15
gofastnut
gofastnut's Avatar
I hit the engine with engine brite and let it soak for about an hour, and this is what I got for the (minimal) effort.
If you look reeeeally close, you can almost see a difference.
Jeff
C-10 Club
Old 03-05-2012, 04:43 PM   #16
gofastnut
gofastnut's Avatar
I think I see the difference: Less dust, more grease visible!
Jeff
C-10 Club
Old 11-12-2012, 11:26 PM   #17
gofastnut
gofastnut's Avatar
So...I've moved twice since last post.(Ugghh!) Been kind of depressed that I haven't done much with her, so, I took the old rear Centerlines off, got some good used tread for the front and rear original steelies, mounted and balanced for $40 - a buddy of mine works at a tire shop.
Figured it was time to pull off the old Barden bumper. I think Grandpa had a fender bender back in the late 70's, I know they did a little work on the bumper, but I don't know that it's been off since it came off the dealer lot. Sorry about that poor schmuck in the pic, I couldn't seem to get ridda him!
Jeff
C-10 Club
Old 11-12-2012, 11:27 PM   #18
gofastnut
gofastnut's Avatar
Oh, and cut that stinkin tailpipe off! It's been drivin me nuts for years!
Jeff
C-10 Club
Old 04-02-2013, 11:34 PM   #19
gofastnut
gofastnut's Avatar
So, I've decided I'm gonna fix her up a little and drive it around this summer. I made a new main power wire, eliminating the ammeter in the cab. Put an inline fuel filter in, and cleaned a bunch of moving junk outta the bed. It's amazing how much 20 firebricks weigh!
Jeff
C-10 Club
Old 04-03-2013, 09:50 AM   #20
Ta2Don
Ta2Don's Avatar
Great Start!!! Have fun, that's what it is all about...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 04-03-2013, 10:55 AM   #21
Jeff La
Progress is good anyway it comes, keep it up
Old 04-03-2013, 11:12 AM   #22
1963c-10
1963c-10's Avatar
Nice build....looks like work is coming along nicely
1964 Short bed trailer
Old 04-15-2013, 12:43 AM   #23
gofastnut
gofastnut's Avatar
WOOHOO
I got the carb rebuilt and got to drive it for about 10 min this evening!! Man, I was sooo stoked! I have put maybe 10 miles on it in the last 10 years, and that was mostly moving it from one storage spot to another.
Couldn't stay out long, I found out my lights don't work.
But I'll be cruisin it around tomorrow for sure!!
Thanks to all you guys and gals for posting your trucks in various stages of repair, and upgrades. It's been great to follow along with you. You've been the inspiration for getting me to get on it.
Jeff
C-10 Club
Old 04-05-2013, 02:58 PM   #24
gofastnut
gofastnut's Avatar
Thanks for the kind words, guys!
I used some Plastikote rust converter on, well, some rusty spots. I'm amazed at how well those spots look after the "treatment" I've been going along the bed where the 147 holes are--yes I counted them. He made and mounted 2 different tonneau covers on it. Getting the rust stopped, going to finish prepping this week and next, then shoot a coat of low gloss equipment enamel on it so I can get some pics taken for insurance.
It's 5 different colors, including the rust, so I'd be lucky to get it insured for $10.
Jeff
C-10 Club
Old 04-06-2013, 09:52 PM   #25
gofastnut
gofastnut's Avatar
jayoldschool, I figured it was original...
Jeff
C-10 Club
60-66 chevy trucks, build
