Old 02-11-2012, 10:08 AM   #1
madcow75
madcow75's Avatar
Question 6.5TD with a/c.... pics/info
I am in the middle of doing a conversion on my, which once was a 1976CC C30 and now a K30. Origanally it was a non a/c cab but want to convert it to an a/c cab. I have a 6.2 diesel with a 6.5TD top end. Has anyone fit the 6.5td in with the a/c in their 73-87/91. I understand that it will not fit without some modification. Any modification info would be nice. Pics would be even better. I have read before an s10 a/c box needs to be grafted on? Also read a possibility of a van a/c box. But I have not really found any solid info or someone with the experience on doing this conversion. . My cab is currently striped and on a dolley ready to prep for the a/c.
madcow75 is offline   Reply With Quote
Old 02-12-2012, 01:48 PM   #2
madcow75
madcow75's Avatar
Re: 6.5TD with a/c.... pics/info
No ones has put a 6.5td top end on a 6.2 diesel and had to deal with the a/c accumulator box.
Old 02-12-2012, 02:22 PM   #3
joe231
joe231's Avatar
I have read all the same info. From looking at pics of the 6.5 turbo I don't know how you could mod the underhood air box to clear. The downpipe wants to occupy the same space as the stock a/c box. You could go with an aftermarket A/C setup for around $1000 or pick up a used Banks set-up for a few hundred more...
I'm picking up a 6.5 turbo set-up in the next few months, but my trucks are non a/c so I won't have that issue.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 02-12-2012, 05:03 PM   #4
madcow75
madcow75's Avatar
Yes I have thought of the banks sidewinder setup. But to find one... and at a resonable cost at that. Aftermarket a/c was a thought also, but still to costly for me. There must be a little cheaper route. I have thought about makeing a custom exhaust manifold or there must be a way to mod the a/c accumulator box a little. I think that I may go to the wrecking yards and look at how much different the van accumulator a/c boxes. I would think they would be a little more compact.
I don't have a tube bender so what are your thought on a square tube exhaust manifold. I could use a cutoff saw for some 45*. Or just purchase a tube bender so I could make some tube manifolds to move the turbo forward. Another thought of mine would to modify a set of military 6.2L headers which I have. Cut a hole for a turbo pipe at the front and weld back up?
Old 02-12-2012, 07:23 PM   #5
tkeduk8r
tkeduk8r's Avatar
i Helped a student of mine swap a 6.5TD into an 82 K10 this summer and fall, and yes the turbo and downpipe want to occupy the same space as the AC box....HE decided to make it a summer cruiser and delete the heater/ac altogether, cuz him bein 18, the turbo meant more I guess... I dont look at things the same way now at 38.. hahah.... again what was said above is true, the banks kit will be needed or a bit of fab work to the top end of the engine.... hope that helps...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 02-12-2012, 09:19 PM   #6
madcow75
madcow75's Avatar
Let me ask this does the exhaust manifold touch the a/c box? If not I might be able to move the turbo forward or toward the intake. With a little fabricating.
Old 02-12-2012, 09:35 PM   #7
joe231
joe231's Avatar
What about building a square/rectangular tube spacer that bolts between the 6.5 manifold and turbo to move the turbo up and forward? I realize it will cause issues with the intake also...
I'm not familiar with the 6.5 stuff, but I wonder if you could flip the turbo assembly around 180* and bolt it back to the manifold and maybe reclock the driven side housing? That would help with both the clearance at the A/C box and maybe give enough room to snake the downpipe inside the frame?
I'm also not familiar with the hummer headers. If they are individual tubes it wouldn't work very well. There is a company online that sells pre made header flanges for the 6.2/6.5 diesels.
http://www.stans-headers.com/gm_flanges.htm
I have thought about building my own manifolds but I would have to pick up a bender as well. I would love to build a custom center mount set-up...
CHEVY ONLY
Old 02-13-2012, 09:06 AM   #8
TexasDmax
What about a vintage air set up? Then you won't have the big a/c box. It's not the cheapest way, but you get new a/c parts that will probably cool better and a cleaner firewall.
TexasDmax is offline   Reply With Quote
Old 02-13-2012, 09:29 PM   #9
jimbonice
jimbonice's Avatar
Iirc, 4bt.com has a couple conversions where an s10 a airbox has been used.
jimbonice is offline   Reply With Quote
