Old 02-12-2012, 12:38 AM   #1
six8burban
Muffler & exhaust suggestions?
Ok I'm looking for something a tad bit louder than a stock escalade with a 6.0 engine? Basically I want a deap throaty sound only when I get on the throttle. So far I have headers and 2.5 collectors. Can I just run true duals with no h or x-pipe and is this good for the engine? Muffler type and offset, any suggestions? Pros and cons from having exhaust exit behind the rear wheels versus under rear bumber? oh and I will not be running cats.
six8burban is offline   Reply With Quote
Old 02-12-2012, 01:00 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Muffler & exhaust suggestions?
half of this is simply exhaust preference, not much specific to the ls engines. I run a true-dual, no xpipe with resonators ONLY dumping out of the step area before the wheels. Its loud, and it does drone on the freeway...BUT it sounds like a damn alcohol car at WOT. I may put some drop in baffles for more daily use, as my neighbors hate me.
Biggest con to pre-axle exhaust is that you get pulled over certain places. Its hard to argue and exhaust ticket...but on older trucks I find the cops tend to leave well enough alone. The rest is pretty much preference imo.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-12-2012, 08:09 PM   #3
harnalien
TruckincrazY
harnalien's Avatar
I've got a video of mine in my build thread. Thrush mufflers dumped and no cats.
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 02-12-2012, 10:54 PM   #4
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Tad louder than stock, BIG magnaflows would me my choice. I have 18x4x9 magnaflows and its very quiet until you get on it. Taking it behind the axle always seems to sound better to me and isn't as prone to drone.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-16-2012, 10:29 PM   #5
52 Rat
52 Rat's Avatar
I've been doing some research on this same topic. It seems the Dynomax Super Turbo's are a good choice for a mild sound. The Hushpower's would be perfect but they seem to be a little pricey.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 02-17-2012, 09:51 AM   #6
Shon
I run 2 22" magnaflows from headers back to rear tires/exit like stock. not too loud in lower RPMs which I LIKE and you can hear it when you press the pedal. I didnt want anything obnoxious for driving this thing around. I did that in another car, gets old.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 02-17-2012, 02:09 PM   #7
OldCreek
OldCreek's Avatar
I run 2 magnaflows, also. No crossover. It's not too loud at low rpms but sounds good at higher rpms. I run it on an open K/5 with 6.0L, camaro manifolds, no cat. I will occasionally blip the throttle when passing under a bridge to hear it!
However, I may be looking for something a tad quieter for my new 5.3L C10 build. It may be a touch too loud for my new build/daily driver. ( At least for me.)
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 02-26-2012, 03:44 AM   #8
flamingbig10
6.0 powered square
flamingbig10's Avatar
I'm running 3" collector to 2 1/2 pipe to super 40s on my lq9 its pretty noisy at any rpm and the inside of my cab has been lizard skinned and phat matted at certain rpms my ears start to ring but I will have the exhaust exit behind the rear tire which will quit it down a little
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
