Old 02-12-2012, 01:31 AM   #1
19seventeeCustom
Throttle Cable?
Hey guys,,
On my '70 project, I'm kinda lost as to what cable I
need to use on the '70 pedal assembly? Can i just buy a universal
kit, I also have a donor vehicle cable from a f-body if those work??
19seventeeCustom is offline   Reply With Quote
Old 02-12-2012, 11:13 AM   #2
mooseknuckles
mooseknuckles's Avatar
Re: Throttle Cable?
I would like to know more as well...I've heard that some use the stock one, and some use the Lokar one.....
mooseknuckles is offline   Reply With Quote
Old 02-12-2012, 05:23 PM   #3
19seventeeCustom
Re: Throttle Cable?
bump for more info!!!
Old 02-13-2012, 07:46 PM   #4
19seventeeCustom
Re: Throttle Cable?
any suggestions?
Old 02-16-2012, 12:36 PM   #5
hotrodimpy
Re: Throttle Cable?
If I am not mistaken the 1970 uses a rod style linkage. If you are converting to a cable style you will need a pedal of some sort. A throttle cable and a bracket to attach the throttle cable at the carburator. The stock parts from a 71-72 can be made to work with your applacation using one of the adaptor plates that are available from one of the venders on this board. Another option is Lokar we have everything it takes to convert to a cable setup it is a direct bolt in kit. Contact us toll free 1-877-469-7440
hotrodimpy is offline   Reply With Quote
Old 02-17-2012, 12:53 AM   #6
19seventeeCustom
Re: Throttle Cable?
^^^carburator???
This is an LS1 swap, I guess I should have been more clear on the
original post...ls1/60e
Old 02-17-2012, 07:38 AM   #7
hotrodimpy
Re: Throttle Cable?
We also have throttle cables and throttle cable brackets for your applacation. We worked with Thorley headers on an engine dipstick to go around the headers also.
Old 02-19-2012, 12:36 AM   #8
19seventeeCustom
Re: Throttle Cable?
do you have a website?? more info on the cables...please
Old 02-19-2012, 12:38 AM   #9
mooseknuckles
Re: Throttle Cable?
check out Lokar.
Old 02-19-2012, 03:04 AM   #10
19seventeeCustom
Re: Throttle Cable?
I've looked at the lokar, but I don't really want to spend $125+ for the
set up, unless there is a cheaper option im missing???
Old 02-19-2012, 10:43 AM   #11
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Throttle Cable?
I would get a pedal out of a 71-72 that is ment for use with a cable then try to use the F-body cable.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-21-2012, 10:00 PM   #12
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: Throttle Cable?
I used a stock replacement cable from 01 Silverado, which is what my motor is out of on my 72 GMC. Worked great, just had to file some 1/2 rounds where the cable goes into firewall. If I were you I would convert over to the 71-72 pedal.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
