Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-17-2012, 12:29 AM   #1
dbash
1969 4X4 $WB $tep$ide Frame Off Re$to Mod
Today my son and I started this project. It is the first of this magnitude for both of us and I am cautiously optomistic about how we will perform.
This is a rolling factory 4X4 frame that we purchased from a member of this site. In fact it was while searching for this frame that I was told about this site and I have since found it to be a gold mine of information for these rigs and I appreciate the time and effort all of you have put in here to give guys like us a fighting chance at a project this large and cool.
We stripped the frame all the way down today and will take it in to be sand blasted next week.
dbash is offline   Reply With Quote
Old 02-17-2012, 12:42 AM   #2
dbash
Re: 1969 4X4 $WB $tep$ide Frame Off Re$to Mod
Stripped Frame ready to blast
1969 truck I have had for five years will donate a bunch of parts to this build;
Stepside Bed
700R4 W/ Overdrive 1yr old
Transfer Case rebuilt 1 yr ago
Front Disc Break Axle rebuilt 1 yr ago
Rear Axle rebuilt 1yr ago
Drive Lines
Misc other parts yet to be determined
Old 02-17-2012, 12:49 AM   #3
dbash
This 1971 1 Ton Flatbed 2WD will donate the following parts;
Cab
Doors
Front Clip (there is one quarter size rust spot on passenger quarter panel so I may use one from the 1969 truck)
We will start to tear down these two trucks next week.
New Parts already ordered are;
LS1 5.3 400 horse from Turnkey (Ouch!)
Deaver 4" lift leaf springs front and rear
Disc break conversion kit for rear axle
Under Bed aluminum Fuel Cell
This should keep us busy for the immediate future. Be patient with us I will try to keep the pictures and posts current as we are able to complete things.
Old 02-17-2012, 01:10 AM   #4
67-72trucks
Re: 1971 4X4 $WB $tep$ide Frame Off Re$to Mod
Awesome project!
67-72trucks is offline   Reply With Quote
Old 02-17-2012, 10:39 PM   #5
dbash
Started stripping out the inside of the 71 cab today. Our "rust free" cab has revealed the first sign of cancer..... I know better then to complain after what I have seen on here but I was sad to see it just the same.
Old 02-18-2012, 11:12 AM   #6
Gene
Gene's Avatar
http://i.imgur.com/6XkPT.jpg
http://i.imgur.com/arVOf.jpg
http://i.imgur.com/gvup0.jpg
Thats a pretty common area to get cancer, mine had it on both sides. Cant wait to see more progress
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 02-21-2012, 03:44 PM   #7
dbash
Thanks for the encouragement guys.
We have made some progress, The cab is completely seperated from the frame now but we have to go pick up my "hoist" today in order to remove it. I will let you see the hoist in the pics of us removing it and the motor and trans.
Sold the original 400 HP motor and Transmission to a local guy off of CL that is why we tore down this truck first.
these 1ton frames sure are a lot thicker then the 1/2 ton Frames are I would love to find one of these in a SWB to build up as a 4X4.
I would have a lot of the smaller parts from this truck listed in the for sale section but I am not allowed to post at this time for some reason. I have registered and I have let the site know.
Were going to tear down the 69 stepside 4X4 the rest of this week. I will post more pics as we get more done.
My favorite part of this project so far? Spending time with my 18 year old son.
2nd favorite? No Metric nuts and bolts!!!
Old 02-21-2012, 10:52 PM   #8
dbash
We brought the "hoist" home and removed the cab today.....
The big brown truck dropped off a box while we were pulling the cab.... I know it bolts to the bottom of the frame I just had to put it in there..... really need to sandblast that frame now
The Motor and Trans ready to be picked up by the new owner.....
Removed the windshield and rear slider from the cab....
Snapped another pic of the 69 its the next one to be torn down!!!
The old Cab and Chassis looks a bit sad.....
Not a bad afternoon.
Old 04-08-2012, 09:10 PM   #9
dbash
Deaver Springs finally here! We began our mock up this weekend starting with the Deaver Springs installed with ORD greasable hardware and shackle hangers.
First we had to cut off the old perches and weld on new ones because the rear axle came off of a two wheel drive frame that was converted and the perches were 3 inches too wide for this factory 4X4 frame.
These Deaver springs look a lot better on this frame then they did laying in my pool room for a couple days! Everything bolted up nicely with some encouragement from a BFH.
So as a result of being a member of this site I discovered Deaver Springs and I am very thankful to those of you that have previously shared your knowladge for us newbies. I can tell they are progressive and soft just by compressing the frame and watching them react as weight is added during the mock up.
I should tell all of you that this frame has previously been media blasted just to make it more friendly to work with and must ask you to excuse the dirt and grime because once were done with this trial run to make sure everything fits were going to take everything apart again and then go to media blast and powder coat with all of the parts. I do not have the experience to do it any other way without being sure I am not missing something.
Yes that is a new LS327 from Turnkey..... I am adding pics of that next.
Old 04-08-2012, 09:29 PM   #10
dbash
LS327 upgraded to 400 Horse Power purchased from Turnkey with a 700R4 transmission married to an NP205. Transmission was purchased a year and a half ago and the TC was rebuilt then as well both were run in this truck behind the old crate 350.
I must say not only does Turnkey build a great motor they know how to ship their product with style. So easy to uncrate and their shipping stand is going to come in handy when we pull the motor back off for the frame to go to powder coat. My engine stand is busy holding up my old 350 that my buddy bought..... going to have to charge him storage soon :-)
I want to tell you that we installed the motor mount adapters that Turnkey provided and the motor settled right down into the motor mount crossmember...... but it didn't!! no fault of Turnkeys, the LS327 is a couple inches wider then the old 350 down where the oil pan meets the block...... some redneck engineering was necessary to let the shiny new motor fit into that old crossmember. I wanted to keep the center of gravity and the transfer case output as low and close to stock as possible so I chose to take on the taske of cutting and reinforcing the crossmember rather then use different motor mounts and lift the motor up an inch or more.
I will have to repair the crossmember once we pull the motor back off. I plan to fill the voids solid with metal and then channel the cross member from the underside in the area where I removed the strength by cutting out the factory channel. Should not be too hard to do. Will include pics when I get to it.
Here is a pic of the notch I had to make on the passenger side of the motor mount, it has a twin on the driver side.
Here is a close up of the same notch if you look you will see the area I removed. It is substantial but it let the LS327 settle in to the factory position nicely and I will strengthen it from the underside before powder coating.
Kicked around drilling and bolting all of the crossmembers and was advised to do so here on this thread as well. Call me an idiot or lazy or whatever but we are welding them. I don't plan to make any changes to this truck anytime soon and I am not crazy about those loose rivits I have found and welding is quicker, stronger and more reliable in my humble opinion.
Just a poser pic of the new motor finally bolted into the frame..... never gets old ;-)
http://i.imgur.com/Ah3X3.jpg
Old 04-08-2012, 10:04 PM   #11
dbash
We also installed a rebuilt steering box and a couple cool parts they sell to strengthen/stiffen the area where it mounts to the frame to eliminate flex and to upgrage to cross over steering. Unfortunatly we caught up to the shipments of parts and will be waiting on the brown truck again before we can finish the crossover steering and install the Reid heavy duty Knuckles on both sides of the front axle. Hoping to have them for next weekend.....
Pic of the rebuilt one ton two wheel drive steering box. This is necessary for the crossover steering because the stock 4X4 box will not work since it is set up to steer the drivers side rather then the passenger side. We also welded on the "frame crack repair" from ORD not that this frame was cracked but while we are here and prior to powder coat I am going to do everything I can to avoid future repairs. We had to apply a lot of heat and work this plate over with a hammer pretty good to get it to lay flat around all of the dimples and against the frame but it came out alright. Still have some welds to do to the bottom but we will finish them after we can flip the frame over again since we have so many others to do from the underside as well.
This Brace is a monster! It will definitly add a lot of rigidity to the steering box and frame. We are going to add a few stitch welds to the front cross member as well.
This little guy is not as impressive as its counterpart in the above picture but it will certianly help.
Old 04-11-2012, 06:25 AM   #12
mcmlxix
Collector of Projects
mcmlxix's Avatar
If you add [img] before and [/img] after the link to the picture, the image will show in the post...
Rich
1972 K5 Blazer CST Click HERE
Old 04-11-2012, 12:56 PM   #13
dbash
Thanks Rich! I was wondering...... fixed the previous pics and will do this from now on.
Old 04-11-2012, 10:37 PM   #14
Mr-Jack
Beer Drink'n Knuckle Dragger
Mr-Jack's Avatar
looking good...what crossover steering did you go with? i'm looking for a complete kit for my 67 1/2 ton 4x4 and what all was included in the kit or did you piece it together
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US
- 67 GMC Long-Wide 350/SM420
My BACON Wrapped Meatloaf Recipe
Mr-Jack is offline   Reply With Quote
Old 04-11-2012, 11:38 PM   #15
dbash
Thanks Jack,
I am using Off Road Design's Dana 44 Cross Over Steering Kit.
They are online at offroaddesign.com I recommend calling them they were very helpfull.
This Kit includes; Pitman arm, Steering arm, Stud kit, (Nuts, cones and studs), Draglink, Draglink ends.
In addtiion to this kit I purchased the following from ORD:
1 1/4" Tie Rod and Tie Rod ends.
A remanufactured 2WD 1ton steering box but you can get a used one and purchase a rebuild kit cheaper if you want. The stock 4x4 steering box will not work for the crossover steering setup.
Passenger and driver side Reid heavy duty knuckles. These are overkill for the type of off road use my rig will see but I dont know how hard my stock ones were beat over the past 40 years so I wanted to eliminate the question. I have these knuckles in my rock crawler steering 42"x 15" wide swampers through the rubicon and they are bullet proof! The cool thing is you can use your stock passenger side knuckle you just have to send it in to ORD and they will machine it to accept the crossover kit for a small fee.
Stage eight locknuts for the axles. These replace the 4 notch locknut that needs to be torqued pretty hard to prevent the hub from coming loose and they are bullet proof as well.
I hope this helps you with yours. Once the brown truck brings all of these parts to us I will be sure to post good pics of the entire cross over steering setup.
Old 04-09-2013, 12:30 AM   #16
Hardesty454
Hardesty454's Avatar
What happened to this build!? This was cool!
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 01-31-2014, 03:52 AM   #17
dbash
I have not been on the site for awhile. Its time to update this build. My Son graduated H.S. and got a great job and I have been busy at work so we both ran out of time to continue this build. I procrastinated for too long thinking we would be able to get back into it and finish it ourselves. Once I came to terms we loaded everything on my trailer and hauled it to one of the best Hot Rod Shops here in Sac. It was a hit to my ego but now that its almost complete I am completely past that. This is going to be a fast completion to an old build thread because this truck has been entered into the Autorama here in Sac this February 14th. The Motor will be fired up for the first time tomorrow and it goes into the interior shop Saturday.
Old 01-31-2014, 04:09 AM   #18
dbash
The pictures will speak for themselves after this short refresher of the key mods and a few words with each pic. Frame holes were welded, full sandblast, satin black powder coat, any part, nut, bolt, washer or clamp that was not powder coated or polished stainless has been cad plated..... I hate chrome..... but is is much less expensive then chrome since you only pay by the pound for the plating process, I simply like the look better then chrome. It keeps the truck from looking like it was just driven through a vat of black paint. You can see the ViAir and the Air tank on the back passenger side of the frame, there will be an accessory air coupler under the step on the passenger side of the bed. Front Dana 44 has an Air Locker. Rear is a limited slip 12 bolt, both have chromoly Axles. LS1 by Turnkey, 700R4, Atlas twin stick transfer case. Custom Drive lines, double cardan joint at back of Tranny and at rear Diff. Vintage Air. Disc brakes all around. Heavy Duty Steering box. Heavy Duty Aluminum Radiator with dual electric fans.
Old 01-31-2014, 04:11 AM   #19
dbash
Close up of previous
Old 01-31-2014, 04:16 AM   #20
dbash
Eye Candy
Old 02-01-2014, 02:12 AM   #21
swamp rat
swamp rat's Avatar
That is one awesome truck!
Would like to know if the springs are 4" lift? if they are can you come up with the brand and length of the shocks you used? Just about everything i find the shock body is too long for my 4" springs or the extended length is too short.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-01-2014, 02:28 AM   #22
dbash
Thanks Swamp Rat. Looks like your doing a great job on yours.
Those are Rancho Shocks. I will not be able to measure anything until its out of the interior shop. I will post them once I am able.
The Leaf Springs were made for me by Deaver Springs. I requested a 4" lift. At that time they told me they typically don't build anything less then 6" but that they would do the best they could to accommodate me. Everyone is convinced it is a lot closer to 6" then 4" depending on how much they settle after being driven some.
If your close you can always weld on some horizontal mount points to help the fit of your shocks.
Old 02-01-2014, 03:59 PM   #23
swamp rat
swamp rat's Avatar
I appreciate the info on the shocks if you can get it. I have BDS 4" springs and ORD shackles, 12" between my BFG 33' tires and the front fender well lip. I have concidered trying to find some kind of shock upper mounts but not sure what to look for or where to look, have seen some for a C10 but not a K20.
As for me I have ether been swamped with OT or sick this winter for the 3rd time, just now getting over a week long bronchitis and fever so things have gotten a bit sidelined since November, i'm getting frustrated to say the least wanting to get the build back on track.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 02-01-2014, 05:08 PM   #24
msgross
msgross's Avatar
Very nice build...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-01-2014, 10:04 PM   #25
dbash
Thanks msgross, and more importantly, Thank You for your service!
