Old 02-18-2012, 12:01 AM   #1
Bethewaz
Assembly Date code Question
Hello all! My first thread!
I have a 1972 Chevy K-10 4x4 and I am looking for a correct engine block. I need to find the date of assembly of the truck in order to get a date correct block. Where do I locate the assembly date of the truck? The glove box door and tag on the drivers door opening are no help. Thanks!
By the way, I am looking for a 350 4bl, manual trans. block........
Bethewaz is offline   Reply With Quote
Old 02-18-2012, 02:54 AM   #2
Achevytruck
Re: Assembly Date code Question
i think the last six numbers in your vin number should have somthing to do with it
Achevytruck is offline   Reply With Quote
Old 02-18-2012, 10:51 AM   #3
DANTIP
DANTIP's Avatar
If you post the following part of your VIN, I think we can get within one month for you. CKE142S167XXX. I would need the part beginning with the plant code (S in this example) followed by at least the next three characters (all numbers). Some of us have collected a significant amount of data on VIN/Build Dates. You can also check the dates on your seat belts.
DANTIP is offline   Reply With Quote
Old 02-18-2012, 10:57 AM   #4
Bethewaz
Ok, Sorry. The vin is: CKE142F152198
Old 02-18-2012, 12:56 PM   #5
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Also check your drivers door in the latch area. There might be an assembly date sticker there. I'm not talking about the Vin tag thats riveted on. What I'm referring to is a blue sticker applied to the door itself. Once you know the month you can lookup the date/model engine codes on the web.
there is also a date tag on the transfer case.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 02-19-2012, 01:47 AM   #6
Bethewaz
OK, THANK YOU! Got it off the door. It is a pretty beat up decal, but reads 2772, which I take as 2/7/72. Good. I found a 4 bolt main block dated D112 which I think will work.
Old 02-19-2012, 09:16 AM   #7
Steve Hafner
Steve Hafner's Avatar
Did you get the date from the upper right corner of the door sticker ?
Below is one from a 72 Longhorn with the date of 2/72 ( February )
Steve Hafner is offline   Reply With Quote
Old 02-19-2012, 10:17 AM   #8
Bethewaz
Oh, that is a forward slash....ahhh. OK, I have a 2/72 as well. COOL. Thank you
Old 02-19-2012, 10:21 AM   #9
Vintage Windmills
Vintage 4x4s
Yeah probably 2/72. What is the full number stamped on the pass side top of deck (in front of head) on the D112 block?
Old 02-19-2012, 10:24 AM   #10
Bethewaz
It is "V0412TRK", (K20, 4 bolt, 175hp)....Closest I can get. I will probably deck it anyway for peace of mind (so everything is straight)
Old 02-19-2012, 10:32 AM   #11
Bethewaz
What is a longhorn?
Old 02-19-2012, 10:33 AM   #12
Sicklajoie
The Niner
Sicklajoie's Avatar
So that's Flint, April 12th.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 02-18-2012, 05:07 PM   #13
Achevytruck
Good to know and its great to be helpful and learn somthing
