Old 02-18-2012, 06:51 PM   #1
lytemup454
lytemup454's Avatar
how do you drop a tank?
hey guy's I'm new to the square body forum. I just bought an 86 1/2 ton gmc. I filled up the passenger side tank this morning and found it doesn't hold gas. I pulled out the plastic cover and now need to drop tank. I was wondering if there is an easy way or the best way to drop a tank that's full of gas.
thanks
ian
lytemup454 is offline   Reply With Quote
Old 02-18-2012, 07:00 PM   #2
Telecasterjoey
Re: how do you drop a tank?
Put a block of wood under it and a floor jack. prolly the easiest. If you can take off the box that's a bonus but not necessary. Remove both hangers from the frame and unhook the fuel lines from the sending unit. Be safe!
Telecasterjoey is offline   Reply With Quote
Old 02-18-2012, 07:29 PM   #3
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Like above stated it is pretty easy. I did it with one of my friends but I could have done it by myself. It will be much much easier if you are able to siphon the gas into another container first though.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 02-18-2012, 09:21 PM   #4
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Pull the filler neck hose and siphon or pump some out , Gas is close to 6.073 lbs a gallon
powerdriver 1958 is offline   Reply With Quote
Old 02-18-2012, 09:39 PM   #5
lytemup454
lytemup454's Avatar
got it out with out issues thanks guys
