Old 02-19-2012, 12:28 AM   #1
redmonster
redmonster's Avatar
Question manifold confusion
Hey amigos need help I'm dumb founded
I have a 250 l6 in my 72 GMC I took the advice of
our compadres from here I put a 292 exhuast manifold
in place of the original one now my truck sounds like its missing
y y y your help is needed
WITNESS
Dont be like me be better than me
redmonster is offline   Reply With Quote
Old 02-19-2012, 12:42 AM   #2
redmonster
redmonster's Avatar
Re: manifold confusion
Anyone
Why does my truck sound like its missing with this manifold
WITNESS
Old 02-19-2012, 12:51 AM   #3
geezer#99
geezer#99's Avatar
Vacuum leak. Did you use a new gasket when you put it back togethor. Are the washers on the bolts in to the head all making contact on the intake and exhaust flanges.
Old 02-19-2012, 01:10 AM   #4
redmonster
redmonster's Avatar
brand new gasket
where could the vacuum leak be
there is also a slight smoke that comes from somewhere if i idle it
hard enough
WITNESS
Old 02-19-2012, 10:47 AM   #5
geezer#99
geezer#99's Avatar
Vacuum leak and smoke could be because your intake and exhaust aren't sealed tightly to the head. Look at the washers on the bolts that hold the manifolds on the head. Make sure they make good flat contact. And you have them all in the right place.
Old 02-19-2012, 12:45 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Can you reinstall the original or was it broken?
Did you install the exhaust/intake complete or just the exhaust?
How is the heat riser? It should move freely. If it doesn't it could be frozen in the closed position.
Plug up all the vacuum ports, hook up a vacuum gauge to manifold vacuum and with can of fuel starter spray around the gaskets to see if vacuum jumps.
Once you're absolutely sure there aren't any leaks, do an ignition tuneup. Distributor cap and rotor, condeser, plugs, points, etc. The miss may just be coincidental.
Also, if you don't find leaks and after you do the tune up it smokes, you may just have worn valve guides or rings.
68gmsee is offline   Reply With Quote
Old 02-19-2012, 01:33 PM   #7
Wrenchbender Ret
You probably have vacuum leaking at one of the ports. 292 engines run hot & often the manifolds are warped. Retorque the mounting bolts. The gasket compresses from the heat & shrinks up. Pull one spark plug wire at a time with the engine running useing insulated pliers. Compare the effect with each cyl. If 2 have little effect & are on the same runner that is where the leak is. If one cyl seems weak check the plug & wire going to that cyl. Sometimes a lot of idling can carbon up the plugs.
Wrenchbender Ret is offline   Reply With Quote
Old 02-19-2012, 03:37 PM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
When you installed it,did you follow factory procedure?The intake and exhuast manifolds need to be gasketed together,bolts installed loosely,then gradually tighten the bolts for the mani fold to head and the manis to one anther.If the intake and exhuast are tightened together before they are tightened to the head they may not be even and seal.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
