Robert Olson Transport
![]() Join Date: Oct 2002
what did you get done 2/19/2012 edition
mine still sits at the body shop. Heres some progress pics.. they hope to have it all in primer this week and then paint soon after that.. I did get my new marker lights this week. its all a matter of hurry up and wait
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Re: what did you get done 2/19/2012 edition
Installed New Smog (AIR) pump and all the hoses. (It looks very official now)
Swapped out my stand by 10-SI for reworked 94AMP 12-SI Alternator (one of the three rectifier diodes went out). Found out that Summit shipped out new Headman headers on Friday!! So all the plumbing work will have to be re-done once the new headers are installed. //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
Tore my engine down. Removed alternator, power steering pump, water pump, intake, carb, dizzy, and here in a few minutes the heads are coming off. I have a set of 305 heads I'm putting on sometime this week, and Crane HMV-260-2 NC (.427 intake lift/.454 exhaust lift, 260 intake duration /272 exhaust duration) cam is going in too.
![]() 305 ci | TH350 | NP208 | 60k miles |
Put 2" drop shackles on my '79 only to get 1" of drop, then oiled hood hinges to get them freed up for new hood next weekend, only to find my water neck on intake cracked/leaks, installed new one.
Got a new dash pad from Pull a Part...Sanded it, Filled the cracks a bit, and painted it
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
Finished painting body panels at last, tailgate and inside of driverside fender was the last. Now only the roll cage left to be painted. Started to re wire rear lights and hitch connector, my old harness is hacked but I managed to get it working so I at least know that I have power back there.
While I have the bed off I made new hangers for the exhaust, itīs now tucked up high so it wounīt get in the way once I flip the rear. But that will have to wait, only 2 weks left until I lose my workshop space, so itīs a rush againt the clock to tie everything up and get the truck back on the road.
Tom.______________________________________ The fleet: 2007 BMW 530xi M (daily driver) 1986 C-10 Stepside (project "my time") 1992 Corvette cab (summer time daily driver) 1969 Cadilac DeVille Cab ("it just need some paint") |
Old Heap Driver
Nothing square body this weekend. I did score a set of nearly new Coker Classic WWW for my '50. Grabbed them from a friend for a single Benjamin.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
My dad got his truck back from getting a new motor, i get to keep the old one to tear down and mess around with. Fixed the exhaust on my jeep, changed some bulbs on my truck and tomorrow will rewire my dome light socket
Rust is better than rice. ![]() |
Added a set of dual cb antennas on the big ol' trucker mirrors to go along with the vintage Cobra radio I have for the truck. True late 70's style.
1969 C-10 short step 1981 CJ7 2017 Ram 2500 Laramie 4X4 1939 Cadillac LaSalle sedan 1950 Allis Chalmers B 1998 Bullet 21 XD 300 Merc/water hot rod |
SC C10 very nice truck im for duallys all the way!! those white rims makes it stand out very good
i sanded down my old crappy tan door panels ,painted em .recovered the inserts with some scrap vinyl and made some aluminum inserts.i dont have the factory trim or any arm rests so i made these out of some scrap i had from another project.first time doing any upholstery work.itl do till i can get new door panels.still gotta get the metal dash painted and a dashpad.also cut off my bumpstop stands and bolted some poly bumpstops to the lower a arm.now it has some suspension travel.also fixed my tv cable for my 700r4 so it doesnt bang on every shift.
I got the headers & accessory brackets back from the p.coaters. Turned out nice for what I have into them. I started getting them back onto the motor today which led to a couple issues I'm working on now.
I seem to be missing some hardware for the belt tensioner so my buddy is going to see if he can get it through GM still. I also noticed on the replacement tensioner assembly that the bearing is made in China where the original GM part was made in USA. I purchased the top-of-the-line @ Oreillys (Gates) vs their house brand specifically to avoid the cheap China crap. I'm going to look up some bearing info tomorrow & might just swap out the bearings if my buddy @ the dealership strikes out.
oh man, I've been bowed up like an anorexic sumo wrestler trying to make weight.
I had to work friday so saturday I got up early and cleaned up the shop after the engine tear down from my black crew cab. then I pulled my toyota pu in to see why It suddenly wants to run like crap, that was an easy diagnose timming chain wore through the water pump ![]()
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
6.0 powered square
I got drive my truck for the first time on public roads for the first time in over year, but ended up striping out all but one seat belt mounting nut, I forgot to strap my battery down and the + battery cable melted against the battery tray when I slammed on the brakes, shut the truck down completely for a couple of seconds the every thing powered back up and truck started right up no other damage found, and I had a small fuel leak found it was coming from the return line on the sender I found out I was using the incorrect flare got that fixed and went to put the lines back on and damaged the flare pieces for the feed line I'll re-flare the line, reinstall the tank, and repair the seat belt nuts and I'll be back in business
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#15 |
Trucks sat for 2 weeks while i went on a trip, got it out today and drove it around. I was missing it. It started right up and took off like when i drive it daily. I'm happy with that.
#16 |
Lots of wiring
#17 |
![]() Join Date: Apr 2009
installed my vintage rear window louvers. (yes, I know the one on the right is crooked. i straightened it up after I took the pic)
This should draw out some haters. Hey, its stuck in the 1970s. what can I say?
1981 Chevy C30 440 Holmes 42K one owner miles |
#18 |
Pulled the cluster out of the stepside, painted the inside white, and replaced the bulbs.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
#19 |
![]() Join Date: Apr 2005
Swapped out 2" drop springs up front for 1" drop springs. Hope that helps with the rim grinding. Also replaced the front section of the e-brake cable.
#20 |
![]() Join Date: Jan 2010
helped the 13y/o pull a 43y/o heart out of a 33y/o patient
#21 |
I got quite a bit done. Replaced the rear shoes, wheel cylinders, hardware and one e brake cable and one stud on our truck. Cleanded up the alt wireing and found out the alt was bad. So i replaced that and took wife and daughter for there first ride in the truck.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
#22 |
Bolted my accessory bracket up to my Gen II LT1, installed the PS pump, alternator and AC delete pulley. Started the motor, belt stays on like it should. Only thing is my alternator is not charging. May be bad. Removed the old manual steering gearbox to make way for the new power steering unit that I am getting next weekend. Picked up my upper and lower control arms from the machine shop where they got new polyurethane bushings and ball joints. Primed and started to paint them. Bolted in my new B & M Megashifter. The PO on my truck installed a tranny mount Lokar 23" double bend shifter. Had to fab a cover plate out of aluminum to cover the hole he cut in the floor. Also installed a new windshield washer resevoir in my 04 Suburban.
#23 |
Finally got started on fixing the cracked frame where the steering box bolts up, some pics. had about 1/2 turn in the steering wheel play.
![]() ![]() ![]() ![]() ![]() Still have more to do but test drove it and it is MUCH better. |
#24 |
scored a factory 73-80 sport bumper off 79 blue monsters truck for $65!
1979 GMC Sierra Classic Freshly lowered 5 inches ![]() ![]() |
#25 |
Rebuilt my mangled 10 bolt.
