02-19-2012, 07:57 PM | #1 |
Picked up my first truck: '84 Silverado!
I have broken this post into sections.
This describes my adventure to get this truck from looking, to purchasing, to driving home. Also gives background on truck: After looking for a truck for some time, I finally found one that fit my budget and had the style I was looking for. It was on craigslist about 1h 15m from my location. I went last week with my father in law to check it out. The truck had only been driven about 30k miles in the last 18 years, so it definitely needed some TLC. It had been painted 8 years ago, and the trans was rebuilt at that time as well, but has pretty much sat since then. The only thing that would need immediate attention before getting it inspected would be the exhaust and headlights. I test drove it and it ran/braked fine, so after thinking about it overnight, I decide to make the purchase. The only thing that made me uneasy was the salvage title. Evidently it was hit from behind, but I got underneath and frame was straight, so no big deal. My wife and I drove down, signed the title, paid the man, and started back on the 75 mile adventure to our apartment. Things went well for the first part of the trip. I was worried about the fact that the truck had sat so long and would now be stirring up whatever trash was in the fuel tank, and stirring up whatever trash was in the carb. About 45 miles into the trip I noticed the truck was not tackling the hills like it did during the first part of the trip, then it began to overheat. I have never been in a vehicle that was overheating before, but I was paranoid about things going wrong, so I noticed the gage and pulled over once it crept past 210F. I opened the hood and smoke came out. I assumed that this from the oil that was dripping from the valve covers onto the exhaust manifold. I shut it off for about 10 minutes, then decided it was better to start it and run it in neutral to circulate the coolant. The temp cooled back down from 260 to below 210, so I took off back down the road. It ran like a champ when I could get it over 60mph, but between 50 and 60 I felt like it couldn’t decide what gear to be in. It was like the torque converter wasn’t locking up. After about 15 more miles, the truck was over heating again and the power loss was worse. Now when going up hills I could not get over 45 miles per hour. There was something definitely wrong, but I couldn’t tell if it was starving for fuel or if it was ignition issues. I was now definitely questioning whether I would make the final 15 miles. I thought, what the heck, lets give it a shot. So I took off down the road again. This time, cooling off did not help, and the power loss started to feel like a time when the points went out on a previous car. When I was about 6 miles from my apartment, I stopped at a traffic light, and when pulling away from the light, I could only get up to 10mph. I knew I wasn’t making it all the way home so I picked a neighborhood and just as I turned in, it died. I popped the hood and took the air cleaner off and told the wife that we should go get some carb cleaner. Then after a few minutes of talking with her, I noticed the truck still had not stopped smoking, like it had previously done. I looked back at the area where the valve cover was leaking and then turned to my wife and said…hmmm my truck is on fire. Two spark plug wires were on fire. The flames were about 5 inches high. My wife gave me her water bottle and I poured it onto the flames and surprisingly it put the fire out. I was ready to take off all my clothes and smother that fire. I was not going to have my freaking new truck go up in flames. My wife joked and called it…flamerado. I think that will be its nickname. All kidding aside, I was very lucky and learned a very good lesson. And that is to be more prepared when dealing with an unknown classic vehicle. I had thought about what I would do if I broke down, but I did NOT think about what I would do if something caught on fire. Assessments after the 75 mile drive home: All four spark plug wires on the driver’s side had burned completely in half and were dangling under the truck. The passenger side looked ok, but I did not like the way they were routed. I think a similar thing could happen on that side, so I will route them differently when I replace them. I think the plug wires did not all burn off at the same time, which is why the truck gradually lost power. This also could explain the overheating? I checked the trans fluid level and the dip stick was dry, So I will add more and see how it does (after I get it running again). I think the low fluid level may be the reason it wasn’t shifting well into overdrive. About the truck itself (options): The truck seems to be a very well optioned truck. Here are the options from the sticker below. Not sure what some of them are. Please feel free to address my questions if you know what the answers are.
Some problems I have noticed:
Short term plans: Plans are to get the headlights straightened out, replace the plugs/wires/cap/button, air/fuel filter, new exhaust, charge AC. I may replace the belts and flush the coolant system. Once I replace the plugs/wires/cap/button/airfilter/fuel filter, I will evaluate whether it runs good enough, or do I need to rebuild the carb (which I really don’t want to do). I also need to figure out why the windows and door locks don’t work. I also need to find out why the dash lights, and dome light don’t work. Here are the pictures: Notice the thing that is at the bottom center of the windsheild, it almost looks like a defroster wire thing? You cant see the wires, but two of the run up the center of the windsheild and then run out to the sides. Original radio? Engine compartment. Goodwrench 350 in place of the orignal 305. Picture of burnt spark plug wires. Also behind the spark plug wires closest to the cab, there is a wire plug that may have melted. not sure what this is yet. Documents I found in the glove box, including an inspection sheet from the date of purchase and the dealership name. Option List. Not sure what some of the options are. Last but not least, my ford lovin', mustang drivin' wife thought it was funny that my truck got towed to my apartment by a ford. I am looking forward to learning more about these trucks. |
02-19-2012, 08:04 PM | #2 |
Re: Picked up my first truck: '84 Silverado!
Very nice truck, you should upgrade your wife just kidding. You'll enjoy your truck a lot.
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
02-19-2012, 08:16 PM | #3 |
Just here to tinker
The wires in the windshield are your antenna. Nice truck!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
02-19-2012, 08:24 PM | #4 |
Nice truck
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
02-19-2012, 08:55 PM | #5 |
That's cool that it got ordered with 3.73 gears. Most of them got a 2.73 or 3.08. Nice truck!
1977 GMC Sierra Grande |
02-19-2012, 08:28 PM | #6 |
Robert Olson Transport
thats quite a story and quite a truck! a complete tune up is definately in order on that truck as well as a complete fluid change but ill tell ya what im betting that youll have one hell of a reliable truck on your hands once ya get it running right.
sounds like it wont be too bad getting it road worthy
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
02-19-2012, 09:32 PM | #7 |
maybe the radiator is cloged + new thermostat
02-19-2012, 11:40 PM | #8 |
the ford floormat is causing you problems.remove it and the demons will be set free
02-20-2012, 12:13 AM | #9 |
Hahaha, I was wondering if anyone would notice the ford floormat.
Thanks for the comments guys. James |
02-21-2012, 04:34 PM | #10 |
haha. flamerado, cool story man and nice truck
02-21-2012, 04:59 PM | #11 |
Ask away!
Here's the questions I saw: Front color keyed FL (Not sure what this means) - color keyed floor, or floor mats High Alt Emission E (Not sure what this means) - different engine emissions package, for like Denver or somewhere AM/FM Stereo ( is this the original one in my picture?) - yep, same as what came in my truck Chrome rear step bumper (not sure what difference is between step and regular bumper) - non step is a more "styled", smoother bumper P235/75/15 TBL S HWY (Not sure what TBLS HWY is, and not sure why it is on the sticker 3 times) - because in the old days you could order different tires on the front, on the rear, and as a spare. This shows they were all ordered as the same tire. XWV = Front, YWV = Rear, ZWV= Spare. XSSL Saddle tan cus (Interior color? Not sure what XSSL is) - "quick spec" for that particular interior combination Tinted glass all windows (as opposed to only windshield maybe?) - yes, although I don't think windshield only was available in our truck. Rear axle 3.73 (this is the standard ratio correct?) -no. Optional Auxiliary fuel tank (how many gallons does each tank hold? 12?) - 16 gal Power steering (var?) - yes Halogen Hi Beam (is this different from regular headlights? What brand should they be?) - brand is unknown. It would be whoever was the production supplier at the time (Sylvania, etc) Chrome front bumper (were bumper guards standard with this bumper?) no - optional P235/75/R15 TBLS HWY (tire size again, but on the other side of the sticker. What gives?) - see above Sequoia special ( What is this?) - optional trim package Operating convenience (What is this?) dome lamp and stuff Exterior décor package (what does this include?) - chrome side moldings and wheel opening moldings 66 Indian Bronze 61 (paint?) -yes Here is the information package for your truck, as located in the GM Heritage Center archive. This will tell you nearly anything you could want to know about what was/is available on this style pickup: http://www.gmheritagecenter.com/gm-h...olet-Truck.pdf You can also send your VIN (and $50) and they can send your original invoice for your specific truck. Follow the instructions on the webpage. I also noticed you have the early (like 1975) style rally center cap. It may be tough to find one of those. You could upgrade to the correct scalloped style cap, like on mine, which would likely be easier to find (below, showing center cap and rear bumper). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-21-2012 at 05:14 PM. |
02-22-2012, 01:41 PM | #12 |
Keith, Thank you very much for the reply! I have been using the search tool to find some of the answers to my questions. I think I am going to post findings to my own questions on this thread as well.
Do you know if my truck was two tone? I believe it was one solid color, "indian bronze". I think it's really neat that you participate in this forum. Having someone who worked for GM on the forum is awesome! I am a quality engineer for a company who makes automatic transmissions for Toyota. Its a neat job, but I think working for an OEM would be even cooler! Thanks again, James |
02-26-2012, 01:55 PM | #13 | |
02-24-2012, 12:51 PM | #14 |
I had a similar problem with my dome light. First check the bulb. If I recall correctly, the dome light should have 12v constantly and is grounded when either the switch is positioned to turn the dome light on, or when one of the doors is open (the switch grounds to the body). So if you don't have 12v at the back of the dome light, you have a broken or disconnected wire. The wire itself runs down the pillar by the driver's side seat belt and then in the crevice between the rocker panel and the floor pan, underneath the carpet. You can find it by removing the plastic "step pad" and lifting up the carpet. The wires should be orange and white. Search the length of the wire for a break. Mine was pretty obvious. Best of luck, and nice ride! I love the 83-84 front end (I have an '83). Cool options, too.
Steve
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
02-24-2012, 05:48 PM | #15 |
Thanks Steve,
I can't wait to start investigating some of this electrical stuff! Ill keep your suggestions in mind. I am not sure of all the differences between the years, but here is my father in laws 83 scottsdale with an 83 silverado grill. He has had it since new. |
02-24-2012, 07:09 PM | #16 |
You should also. Check and see if the motor is grounded out as well could be why plug wires melted
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
02-26-2012, 01:33 PM | #17 | |
Broey, I agree with you. Ill check the fuse box first, and if fuses are blown, ill look into why they are blown and then replace them.
I didn't think about this, but you might be on to something. I noticed a ground strap just 'chillin' over on the drivers side. It is not connected to anything (on either end). I am not around my truck this weekend to investigate further, but you can see it in a previous picture I took: I feel like this is a dumb question, but where is the engine grounded? To find where the engine is grounded should I just look on a wiring diagram?The negative battery cable is connected to the frame, is that it? |
03-03-2012, 01:04 AM | #18 | |
Home Built '87
Negative battery should be connected to the frame as well as the engine block. You should also make sure the body has adequate grounds between it and the frame as well, don't just rely on the bolts to do this. Do at least one for the cab, one for the rad support, one for the fenders and a separate for the box. Might be overkill but it might help solve some wiring gremlins. Might be a good time to check all of the grounds that you can easily access to make sure a ground wire hasn't broken off somewhere along the line. That loose strap might be a ground for the under hood light if you have one. If you don't and it isn't connected to anything, remove it and use it somewhere else. Nice truck too btw!
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
03-03-2012, 01:26 AM | #19 |
Thanks Gordon,
I looked the truck over and found several ground straps. ALL of them need to be cleaned. Right now my focus is to get the truck inspected and legal so it wont be towed from my apartment complex, then I am going to use some purple power to clean all the nastyness off the engine. From there I will remove all the ground straps I can find and clean them. |
02-25-2012, 12:27 AM | #20 |
^^who I am^^ what I say>
I love this truck. The 84 style grille is my all time favorite, Im pretty jealous!
70 chevy LWB 350/TH350 Barn find (AKA the 70) http://www.67-72chevytrucks.com/vboa...d.php?t=406364 East Tx Squares |
02-25-2012, 02:11 PM | #21 |
WOW, that red/white truck is beautiful...that's got to be the sharpest color combo on that bodystyle...I'm not into customization but the cowl hood is subtle & keeps the truck looking classy.
I forgot to mention earlier...the previous poster mentioning the "always hot" dome light reminded me...I've seen a lot of these trucks & S10's wiring corrode/disintegrate where it runs under the carpeting/rubber mat...I guess it's from the constant moisture under there. My S10's wire was so bad it had literally separated in two.
Jel |
02-25-2012, 04:53 PM | #22 |
I drove down to my parents’ house in charlotte this weekend. I found some of the spark plug wires I pulled off of my corvette a few years ago. I’ll probably put them on next weekend (when I'm back in Raleigh) and I'll also investigate the interior lights and power windows.
I'll plan to take back my voltage meter, and several other basic tools. I hate being in an apartment complex. |
02-25-2012, 05:14 PM | #23 |
Here is what I found about the Sequoia Special . This was copy and pasted from an older thread by KIILEW:
Sequoia Special The Sequoia Special was the spiritual successor to the Bonanza/Bonanza packages of the '80 and earlier time frame, which in turn descended from the even earlier Highlander discount option packages. While the earlier packages were specific option groupings priced at a discount, however, the Sequoia amounted to the proverbial "buy several options, get one free" scheme, and were apparently offered during the winter/spring months. Specifically, the buyer would receive either C60 air conditioning OR MX1/MX0 3spd/4spd automatic transmission WITHOUT CHARGE if he selected the following options: ZY4 deluxe two tone paint (not color specific, with contrasting color on the roof and lower bodyside) V22 deluxe front appearance package (i.e. chrome grille/quad headlamps) TT5 halogen high beam headlamps U35 electric clock A01 tinted glass ZQ2 Operating convenience package (i.e. power windows/locks) U58 AM/FM stereo radio (w/an upgrade allowed) K34 electronic speed control N33 tilt steering wheel CD4 intermittent windshield wipers The overdrive auto transmission discount was applicable only to 1982 and later 1/2 and 3/4 ton pickup models which normally offered that transmission on an RPO basis. The package content was likely fairly consistent from year-to-year. Other than the reference to the "YH6 Sequoia Special" listed on your glove box label, these models are indistinguishable from similarly optioned (non-discounted) vehicles. |
02-25-2012, 09:53 PM | #24 |
Square
Sweet truck! Total score on the cargo light. Hopefully a change out of some fuses will fix the interior electrical issues.
Squarebody Syndicate |
