Cam change,need install info
When I go to pull the cam out of my sbc 67 c10,will it clear the grill? Thanks guys!
Re: Cam change,need install info
on my 71 i pulled the grill for the extra room measure length of new cam and measure to be sure ,
Grandpa in the rustmobile...
I pulled mine out with just removing raditator/shroud.
If you put long bolts in the front of it the bolts WILL NOT clear the grille. Put the bolts on and use them for a handle so you dont bang the cam around then when you get 2/3 way out remove the bolts (or have someone remove them) and it will clear the grille fine. Ps mine was a 68 c10 with the facotry v8 motor mounts
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
