Old 02-23-2012, 12:22 PM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
v6 to SBC question
Are the motor mounts for the 4.3 V6 the same as the small block?
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 02-23-2012, 01:51 PM   #2
Jonboy
Slots go on anything!
Re: v6 to SBC question
They should be the same. All of your accessories should swap over, too.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 02-23-2012, 09:23 PM   #3
Weasel Diesel
Not in an 86....
I just got done with the 4.3 to 350 swap on my 86 c10. Here's what I dealt with....
Go to boneyard and get L6/V8 frame pedistals for motor mounts to bolt to (V6 is different )
V8 motor mounts & clamshells ( V6 clamshells different ).
The trans. can bolt up to the V8 Ok. Flywheel depends on whether you are running 2 piece rear main or 1 piece engine.
If you run full length headers, the drivers side exits straight into the crossmember and you will need to get custom exh. None of my local custom muffler shops would touch it because they said that because I changed the engine, it did not conform to the factory emissions standards. Summit has a kit # WLK-89007 that fit like a glove. Took me about an hour to install it.
I was able to reuse the pullies, brackets and stuff for the alt, PS, stuff. Throttle cable did ok as my 4.3 was a QJ.
New radiator, then I ran a dual electric fan setup.
Of course different hoses for cooling system
Probably a few other misc. things I am forgetting.
Weasel Diesel is offline   Reply With Quote
Old 02-23-2012, 11:30 PM   #4
C-10 simplex
But let's say you're using the stock 6cyl exhaust manifolds---will it interchange with the v-8 stuff?
C-10 simplex is offline   Reply With Quote
Old 02-24-2012, 02:14 AM   #5
gramps
No. The v6 exh manifolds will not mount on a
V8.
gramps is offline   Reply With Quote
Old 02-24-2012, 09:29 AM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
IIRC as its been about 8 years since i did this i was able to use my mounts but i had to buy the v8 Y pipe and use that with the stock exhaust from the 6
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-24-2012, 11:49 AM   #7
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I guess it would be smart to just buy a used set of V8 mounts to avoid any potential trouble. Do you move the mounts to differnt holes when you do the swap or are yall positioning the V8 in the same spot the v6 was in?
Old 03-18-2012, 12:48 PM   #8
C-10 simplex
What i meant was, will the 8's manifolds bolt to the six's exhaust system----y-pipe?
