Old 02-25-2012, 04:47 PM   #1
Stepper86
Stepper86's Avatar
What is this wire for?
Hi guys.
I have two wires on my firewall that I can not find a purpose for. They are identical. One is on passenger side and the other is located in the same spot driverside. Green wire with an orange connector. Any one know what they are for?
I have a wiring diagram but I had no luck finding them.
Tom.______________________________________
The fleet:
2007 BMW 530xi M (daily driver)
1986 C-10 Stepside (project "my time")
1992 Corvette cab (summer time daily driver)
1969 Cadilac DeVille Cab ("it just need some paint")
Stepper86 is offline   Reply With Quote
Old 02-25-2012, 04:59 PM   #2
Telecasterjoey
Re: What is this wire for?
I have the same one on my truck and it's not plugged into anything!
Telecasterjoey is offline   Reply With Quote
Old 02-25-2012, 05:13 PM   #3
Stepper86
Stepper86's Avatar
They donīt appere to have been plugged in on my truck eighter, no scratches on the connecting point. Every thing works on the truck so probably not needed. It would be interresting to know what they are for. Maybe some option that I donīt have on my truck?
The fleet:
Old 02-25-2012, 06:03 PM   #4
notallthere
That one looks like it could be a kickdown wire for a TH400. I have no clue on the other side.
notallthere is offline   Reply With Quote
Old 02-25-2012, 06:26 PM   #5
beamn7
Pretty sure that Driver's side is TCC diag plug to be used with a test light and pass. side one is for monitoring exhaust readings / adjusting carb using a dwell meter set to 6 cyl scale. Should vary between 25 and 35 ohms while running.
beamn7 is offline   Reply With Quote
Old 02-26-2012, 03:01 AM   #6
Stepper86
Stepper86's Avatar
[QUOTE=beamn7;5212202]Pretty sure that Driver's side is TCC diag plug to be used with a test light and pass. side one is for monitoring exhaust readings / adjusting carb using a dwell meter set to 6 cyl scale. Should vary between 25 and 35 ohms while running.[/QUOTE
Thanks for clearing that out, now not only do I know what they are for I will plug on a meter and see what readings I get, Had my carb opened recently and itīs still not running like I want it too.
The fleet:
Old 02-26-2012, 08:01 AM   #7
Weasel Diesel
The one on the Pasenger side was for Option # 2534... " Loose women detector" and the driver's side one was for Option #9586... " FREE Beer detector". Sorry...couldn't resist...
Weasel Diesel is offline   Reply With Quote
Old 02-26-2012, 09:15 AM   #8
Stepper86
Stepper86's Avatar
Hehehe....... My guess is those options were listed on GM-option Appendix-XXX. This rare document was for obvious reasons only shown to a feve carefully selected buyers
The fleet:
Old 02-26-2012, 11:32 PM   #9
beamn7
Make sure your base settings are good (timing, etc) then set the idle mixture screws to 3 complete turns out. Connect the dwell meter set to 6 cyl scale and allow the vehicle to reach operating temp. To make adjustments to the readings turn the idle air bleed valve in the center of the air horn of the carb. Turning clockwise leans the mixture and counterclickwise richens. The lower the reading on the dwell meter the richer the mixture is. Aim for 30 degrees but the reading will be varying back and forth. Make small adjustments and allow the mixture to stabalize each time. Go no more than 1/4 of a turn at the most each time.
If you have a throttle posistion sensor (TPS) open up the connector (with it still connected to the sensor) and check the voltage with the key on, engine off and the choke all the way off. Voltage should be checked between the middle and the bottom wires. Should be .48v for a 350. I run mine at .50v If you need to adj, there is a screw just behind the accelerator pump lever.
Hope this helps.
