Sway bar choices
Can anyone recommend a front sway bar for a 1965 C10. I have seen alot of aftermarket brands, which ones fit the best w/o having to modify anything?
Re: Sway bar choices
I get them for 55-59 trucks from CCP. They are good vquality & fit good.
I got my Sway Bar from the local Self Serve wrecking yard. A front sway bar from a 67 - 87 Chevy Truck is a direct bolt in. I pulled mine from a 77 One Ton truck. It's 1-1/4" in diameter and set me back a whopping $20.30 A little time with a wire brush and rattle can of Satin Black spray paint and you're good to go.
Here's a fantastic link that should answer all your questions: http://67-72chevytrucks.com/vboard/s...ad.php?t=72338 |
if it was at a pull your own part,i would like to know how you removed at the yard/ thanks
#5 | |
Resistance is Futile
I used one off a 67-72. Got new bushings from Auto zone; painted gold!! ![]()
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
I got mine form a pull a part off of a square body. You should grab the brackets while you're at it. IDK why but the truck I got mine off of had bolts instead of rivets so it was easy. Luckily it was the 1st truck I looked at too. IDK if they're all like that or not.
BTW if you're lowered you don't need those brackets. Just get new bushings, mount to the A Arms first, then hold it up to the frame and figure out if you need to drill 1 or two holes for the frame mounts. We did this on my buddy's squarebody and it worked great.
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201 no garage, no shop, limited storage space and tools....no problem. |
![]() Join Date: Jan 2010
I originally was going to use the 1/2 ton swaybar on the 86 front I'm bolting under the 66. Then after reading on here. I found a 1 ton bar off an 84. Then goin to do the factory iroc rear bar
Posted via Mobile Device |
sway bar options for 1960-1966 trucks
as Wrenchbender Ret. mentioned, CPP sells 'em. Early Classic Enterprises also sells the sway bar, the brackets, bolts and bushings... all together or separately. -W update/edit : Make it handle : August 2010 /+1600 posts all years, all sorts of trucks... lots of golden information in this one. This is the thread scottofksu mentions below. Be sure to explore the 60-66 FAQ Index for more links to threads and articles about sway bars. If this link disappears/changes, the 60-66 faq is maintained as a sticky at the top of the 60-66 message board forum. Last edited by Woogeroo; 11-21-2013 at 05:25 AM. Reason: updated URL for sway bar article |
Who Me?
Great thread!! Subscribed.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
You should check out the "Make it Handle" thread In the suspension area. It will blow your mind... Reason I mention it is that the optimal sway bar size is discussed somewhere in the thread as is the best types of bars to consider.
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
