![]() Join Date: May 2010
Help with engine ID stamp
I have done a couple of searches and not sure I have come up with anything yet and thought I might see if one of you had any answers or places to steer me to.
I got the old engine "slightly" clean...enough anyway to see the ID stamp on the block. The numbers are 110200992 TO624CGO. That is at least what I think it said in the dark ![]() Any ideas? Thanks in advance! |
Re: Help with engine ID stamp
Double check the numbers, I think it's probably "CGC" which would be a 350 from a '71 camaro or chevelle.
Thanks guys! I will definitely recheck the numbers but I am sure it is a replacement engine. Just need to make sure what I have for the rebuild.
member #16
![]() Join Date: Dec 1999
Heres a site to decode the suffix no's. I dont see a CGO listed. Maybr clean and look again.
http://www.nastyz28.com/decode.php
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
I checked my chevy books and did not find a "CGO" , but did find a "CGC
![]() Which comes up as a pass full size car from 1971 with a 350/with 245hp! Clean the pad better and see if this matches up?? Most truck #'s started with a "T" @ TKO TGH and so on. You can check the back of the block for casting numbers,and also the head casting numbers!! ![]()
