02-27-2012, 09:29 PM | #1 |
Rear bumper installation and sag question
Whats up guys I just bought my first truck and am about to start restoring it. I took a few pics for ya'l to help me out because i'm about to buy a rear bumper for it and wanted to know if all i need is the mounting brackets and the bumper. It looks like it was cut before so i need to know exactly what i'm gona need.
Also my bed sags on the rear of the driver side. The front of the bed looks straight its just the driver side rear corner. Has this happened to any of your trucks if so what was it? I was just curious and thought I might as well ask before i start getting into it. Any help is appreciated thanks.
71' Chevy C10 Stepside My Build Thread http://www.67-72chevytrucks.com/vboa...d.php?t=511087 |
02-28-2012, 12:22 AM | #2 |
Re: Rear bumper installation and sag question
anyone got any tips?
02-29-2012, 12:25 PM | #3 |
02-28-2012, 12:18 PM | #4 |
Your frames been cut from a long bed to a short bed. It looks like from the first picture that the frame is bent, also.
You may need to remove the bed to get a better look at the frame. Do the coil or leaf springs look the same on each side? Same size tires?
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
02-28-2012, 01:12 PM | #5 |
Would this fall into the category of "Who's bought a truck and then found..."?
Cheers and good luck with that, |
02-28-2012, 01:45 PM | #6 |
There's going to be some fabrication involved to put a bumper back there. Good luck. I'd take the bed off and see how they shortened the wheelbase.
Doug Looking for a 67-72 short bed driver..... |
02-28-2012, 02:31 PM | #7 |
I'm not sure that your frame has been shortened - it may have just had some notches cut out of the ends. Ask someone with a short step to post some pictures. If it is a longbed frame, the sectioning is done most normally behind the cab. Take a look to see if you can see the cuts and welds if it has been done. It appears that there is a spacer between the frame and bed on the back mount on one side and not on the other side in your photos. If that is the case, the corner with the spacer will obviously be higher. Join the board and post a wtb ad for a set of used stepside sport bumper brackets. I am sure that you can get them bolted/welded on. It will be easier for correct placement if they are bolted to the bumper you are going to use.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
02-28-2012, 02:54 PM | #8 | |
The Older Generation
To shorten a long bed frame you take 12" out of the middle but you also take 8" off of the back of the frame rails.... So they cut the notch then just torched off the part that stuck out beyond the bed. LockDoc
02-28-2012, 03:41 PM | #9 |
Doesn't sound too good gona have to check it out afterwork. Does anyone got any pictures of what other part of the frame is cut to shorten it? Also if it is cut what kind of problems does that cause.
02-28-2012, 08:46 PM | #10 | |
LockDoc
02-28-2012, 11:09 PM | #11 |
Thanks for the heads up I appreciate it fellas. Now just time to get this bumper put on.
02-28-2012, 11:11 PM | #12 | |
02-29-2012, 12:27 AM | #13 | |
No problem. I hope you find a satisfactory modification... Any more questions ask 'em up... LockDoc
02-29-2012, 01:36 AM | #14 |
ok then out of curiosity how did you put your bumper on? got any pics or tips?
02-28-2012, 04:04 PM | #15 |
Leon's right. I had forgot the 8" that is usually cut off the back in addition to the 12" off the wheel base up behind the cab.
02-29-2012, 07:08 PM | #16 |
I guess you could always shim "up" the low sides of the bed and the cab...
