Old 02-28-2012, 03:33 PM   #1
Coryd501
1950 Chevy rear end problems? newbie
I just bought a 1950 chevy truck and while trying to replace a wheel cylender I noticed two things 1. I have an axle that I have no clue were it came from and 2 they used the factory leaf springs and now the shackles are bent. Ill attach the pic of the shackles. I need a cheap option please!!! but I want to make it right. open to anything TCI leaf kit / Juck yard ...
The only stamps on the axle are HA 10 06 W
Thanks guys!
Coryd501 is offline   Reply With Quote
Old 02-28-2012, 05:16 PM   #2
oldcouple
oldcouple's Avatar
Re: 1950 Chevy rear end problems? newbie
Are your axle perches welded or just bolted on? Looks like they have moved in board, or someone just used the stock ones which caused the springs to twist.
look here: http://www.thecamaro.com/Decoding/Ch...Axle-Codes.php
http://www.novaresource.org/axle.htm
http://aplsweb.com/Topics/Differential.htm
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 02-29-2012, 11:01 AM   #3
gmcer
to me the bushings are toast and/or bolt goin threw the springs is shot. easy fix
gmcer is offline   Reply With Quote
Old 03-11-2012, 05:02 PM   #4
Coryd501
[QUOTE=oldcouple;5218975]Are your axle perches welded or just bolted on? Looks like they have moved in board, or someone just used the stock ones which caused the springs to twist.
the perches are welded but that axel didnt come original in that truck. Still cant find anything for that axel code. found some wheel cylinders that fit but now I have to find a pinion seal for it. Thanks
Old 03-12-2012, 01:49 PM   #5
oldcouple
oldcouple's Avatar
Fixed your pic, it was giving me a neckache
Old 03-12-2012, 02:56 PM   #6
Coryd501
That does help. Im starting to lean to a 1965 rear end from a truck non posi. but just a hunch I still have yet to find anything on it besides being a 12 bolt but here is a pic
