02-29-2012, 01:51 AM | #1 |
need new radiator
I am in the process of doing some research, I am having a hard time finding a new radiator for my 66 k10. Anyone have any suggestions?
02-29-2012, 02:30 AM | #2 |
60-66 Nut
Re: need new radiator
Have you tried your local auto parts supplier? There are several members here that have had good luck with the aluminum radiators found on ebay. A simple search here should show a couple threads on them.
02-29-2012, 03:18 AM | #3 |
Thats good to know about the ebay radiators, I was kinda thinking they might be a little chincy.
02-29-2012, 07:32 AM | #4 |
02-29-2012, 10:03 AM | #5 |
amccomb:
Read all about it here. Mine came from RockAuto. You will see the details in my post on this link. Regards, Steve New Orleans http://67-72chevytrucks.com/vboard/s...d.php?t=479431 |
02-29-2012, 10:19 AM | #6 |
I bought one of the ebay aluminum ones around 3 years ago for my 63 daily driver and have not had any problems with it. Was quite satisfied with the price and quality.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
02-29-2012, 10:42 AM | #7 |
Do you know there are 2 sizes of rads. A narrow one for the six. About 18" wide. And a wider one for the V8. About 22" wide. Also different mounts. Watch when you go shopping as some vendors only sell the wider one.
02-29-2012, 10:49 AM | #8 |
I bought a champion off E bay.
62 long box with a little SBC http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
02-29-2012, 10:53 AM | #9 |
Champion was the brand I went with also. I like the cap with the blow off chain. Cant seem to find them aftermarket though....thought that was weird. I've had a bunch of people ask me where I got the cap from.
02-29-2012, 11:39 AM | #10 |
I have a champion also on my LS swap, keeps everything cool in 105 degree temps with AC on and running in the city.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-29-2012, 01:51 PM | #11 |
Sometimes old trucks that sit for years the radiator gets plugged. I remove them. empty them. Put the rad cap back on and lay it flat with the openings faceing up. I then fill the rad with white vinagar and let sit for two hours. Rince and repeat. I usually do two wash/soak cycles. Then rinse with a garden hose for a good ten minuets. Good as new then!
03-02-2012, 07:35 PM | #12 |
Thanks guys thats good to know about the two radiator sizes since my truck was oritginally a 6 and is now a unknown small block v8. Does it matter how many core's I go with I guess 3 might be a better idea?
03-03-2012, 01:48 AM | #13 |
60-66 Nut
A 3 row core with a shroud will cool most small blocks, and even some big blocks.
