02-29-2012, 01:43 PM | #1 |
Losing coolant out of radiator?
I have a 1972 Cheyenne with a 350 motor and I have been noticing lately that I am losing coolant out of the radiator. It is enough so when I look into the radiator I can see the top of the coils and such in it. I have not been seeing any water leaking out of it when I stop or any steam coming out anywhere when running the motor. The motor has not been running hot either. I did notice that the whole passenger side of the radiator running down the side is covered with a bunch of greenish junk. Any suggestions or is this normal? Thanks in advance for any help.
02-29-2012, 01:47 PM | #2 |
Re: Losing coolant out of radiator?
It is normal to get greenish junk running down the passenger side of the radiator. The factory system doesn't have a closed system. If you keep filling it up to the top it will keep coming out the overflow tube. Stop adding and keep an eye on the temp gauge. "Normal" is a couple inches down from the top of the open radiator cap. Only check when cold of course.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
02-29-2012, 01:54 PM | #3 |
Okay thanks, guess I used to new vehicles and how they are always full to the top. Oh and the greenish junk is actually on the driver side, I misspoke. Thanks again.
02-29-2012, 02:08 PM | #4 |
Now that is a different story. You should probably look at where the greenish junk is coming from. If it isn't the overflow tube (passenger side) you have a leak. Does it go all the way up to the radiator hose? Make sure that clamp is tight.
02-29-2012, 02:18 PM | #5 |
I replaced all the hoses not long ago because they were looking a bit brittle, and the clamps are tight double checked that a bunch of times. The green stuff is all down that side right underneath the where the top part meets the fins and about an inch into the radiator. I think it might just be time for a new one it was on the agenda anyway. 40 years is a long time for a radiator to last might as well bite the bullet. Thanks again, you certainly helped a ton.
02-29-2012, 08:07 PM | #6 |
Active Member
I would take it to a radiator shop to have it checked. Not sure how much it costs over there but a few years ago I had mine rodded and checked for leaks -cost was about $40.
Afterwards, install an overflow tube. They're cheap and easy to install and keeps you from having to add water/antifreeze to the truck on a regular basis. |
