Old 03-01-2012, 02:24 PM   #1
hotrodwest
hotrodwest's Avatar
5.3 LS A/C compressor mount in 72 chassis
I'm putting an 04 5.3 LS engine out of a Avalanche into a 72 Chassis. I reading the various build threads I know I need to clearance the frame for the compressor lines. The problem I have is the engine mounts interfere with the compressor mount. I have the flat plate mount adaptor that mounts the LS engine in the old chassis but it puts the engine mount too far farward on the engine for the compressor to mount. Any suggestions? Thanks
hotrodwest is offline   Reply With Quote
Old 03-02-2012, 03:08 PM   #2
Z1971
Z1971's Avatar
Re: 5.3 LS A/C compressor mount in 72 chassis
Alan Grove makes some brackets for the LS. They list the dimensions. Hope it helps, the are about as cheap as you can find. http://www.alangrovecomponents.com/LS.htm
Z
1971 LWB Ochre
Z1971 is offline   Reply With Quote
Old 03-02-2012, 07:11 PM   #3
Clyde65
Clyde65's Avatar
Kwik Performance make a high mount (pass side) AC bracket also
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-02-2012, 10:51 PM   #4
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
I had to trim off part of the AC bracket to make it fit. No issues after that...
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 03-02-2012, 11:55 PM   #5
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Check the LSx swap FAQ linked in my signature.
Motor mounts
http://67-72chevytrucks.com/vboard/s...d.php?t=413855
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 03-03-2012, 12:03 AM   #6
mcbassin
Still Learning
mcbassin's Avatar
What he said ^^^
I used the stock compressor on mine. I also used the 73 up style motor stands and mounts. I did have to modify my adapter plate as Glock recommended in the link above. I also made a brace to carry my pass. side engine stand. Pictures HERE
Old 03-03-2012, 12:09 AM   #7
hotrodwest
hotrodwest's Avatar
thanks for all the responses. I will ck them out and let you know how it turns out.
