03-08-2012, 05:45 PM | #1 |
1972 blazer tear down phase
Bought my 1972 blazer a few weeks ago and have been spending as much time as possible gathering parts and tearing her apart! Figured I would post some pics and show ya'll how its been going. Appreciate Any tips or comments!
03-08-2012, 05:56 PM | #2 |
Re: 1972 blazer tear down phase
First two pics!
03-08-2012, 05:59 PM | #3 |
Top on for the first time.
03-08-2012, 06:00 PM | #4 |
Tearing it down!
03-08-2012, 06:06 PM | #5 |
Almost ready to pull out the motor!
03-08-2012, 06:11 PM | #6 |
The pictures of the top above are of a single wall i found near where I live. I really lucked out finding it because the top I have on the blazer now is a double wall... but, my blazer has the holes for a single wall.
Plus this single wall I found is in terrific shape, minus it's hatch! There weren't cracks or weak spots in the fiberglass which my double wall is full of. But on another note, has anyone drilled holes in their bed for putting on a different type top? Just wondering if it is as easy as just drilling the holes??(because I was thinking about maybe keeping both tops) |
03-08-2012, 08:30 PM | #7 |
let me know if you need anything. I tore mine down a few times now and have it down to a science haha... many people probably do. Just do yourself a favor and dont cut the wires. If you plan on rewiring it with original or with aftermarket it is still helpful to have it intact for reference.
03-15-2012, 10:22 PM | #8 |
Well I am about to begin on my floorboard replacement. Ordered the complete floor pan (I'm going to need it lol) but I had a question on replacing the rocker panels. Do I need to order a inner rocker panel along with the outer? Or is the inner part of the rocker panels a part of this complete floor pan? I'm a little confused..
Posted via Mobile Device |
03-16-2012, 09:16 PM | #9 |
You've got a lot of options for patching in replacement panels, but you are correct that the floorboard curves down to form the inner rocker panel.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
03-16-2012, 10:24 PM | #10 |
Thanks 71restorod. By the way, I live your blazer. It's just what a beauty looks like! Hope one day mine will be as nice. What size lift/tires you have?
04-18-2012, 10:13 AM | #11 |
Havent posted in awhile, heres whats been going on!
04-18-2012, 10:17 AM | #12 |
Some more..
04-18-2012, 10:21 AM | #13 |
I went to greenville, tx to pick up the back seat. Thought I was never going to find one! I also went to fort smith, ark to get these doors and this grille.
04-18-2012, 10:25 AM | #14 |
I mean these doors!
04-18-2012, 05:08 PM | #15 |
What was wrong with your blue doors?
04-18-2012, 05:32 PM | #16 |
The bottoms were nearly gone completely. rust!
04-18-2012, 06:35 PM | #17 |
ah unfortianate! Hope you got a good deal. I may have an extra set of wing windows laying around somewhere.
04-18-2012, 06:41 PM | #18 |
I have them off my others. I paid I hundred, I thought it wad a decent deal..
05-02-2012, 12:31 PM | #19 |
Had some progress the last week. Refer to the earlier pics for a then-now of the floor and front end!
05-02-2012, 12:36 PM | #20 |
The last pic is after i painted rear end and undercoated bed!
1967 SWB C-10 1972 Blazer 4x4 2011 Silverado |
09-01-2012, 01:15 PM | #21 |
where did you find floor pan
09-01-2012, 02:08 PM | #22 |
I ordered it from topbanana.com. it is a truck floor board tho, it takes some major tweaking. like welding on nuts for bucket seats and shortening the floor. But it was really the only choice for me and it worked out really nicely!
09-01-2012, 04:44 PM | #23 |
Thanks i got a cab floor assembly from LMC for 67-72 truck with all braces just seem so much bigger .Hope mine turns out half as good as yours looks Good looking job, thanks again for input
09-01-2012, 05:43 PM | #24 |
No problem. I ended up cutting the back off about 10 inches or so (where the gas tank on a truck would set) and then i cut it split down the middle so it could slide in much easier and that made it much easier to get it where it needs to be! Just don't forget to get some nuts welded on, for your bucket seats, before it goes in. (you can't get to like four of the nuts once its in because they set over the torsion boxes)
09-01-2012, 09:24 PM | #25 |
is that a 2WD rearend?
Tags |
1972 blazer, blazer build |
