Old 03-09-2012, 12:32 PM   #1
shipma3
Cool 12 bolt rear end info ?
what gear ratios did they come in for half tons and are the a good axle for offroading? im know my 1978 k10 has a 12 bolt rear and i think its a dana 44 front. are these axles good?
shipma3 is offline   Reply With Quote
Old 03-09-2012, 10:26 PM   #2
Zoomad75
K5Camper
Zoomad75's Avatar
Re: 12 bolt rear end info ?
The 12bolt and D44 are decent axles to start with, provided you don't go too large with the tires and lock them up. 35" is about as large as I'd go. Yes people have gone larger on them, but that doesn't mean they survive for long off road.
There is a pretty good selection of ratios for both. Keep in mind the major downfall to a 12bolt axle is the fact that it's a semi-floating c-clip design. Meaning the only thing that holds the axleshaft in the housing is a c-clip inside the differential. While that seems ok, wait until you bust an axle shaft and what's left is going to start walking it's way out of the housing, wheel, brake drum and all.
If you don't plan on going large or being a uber-rock crawler they will last. I've wheeled for a while on a 12b/d44 combo. I didn't lock it up though on either end with my 35" tires. I'm careful (sometimes) on the throttle and try not to bite off more than my rig can chew (again sometimes!). I'm still planning on upgrading at least to a 14b full floater for added beef/security.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 03-10-2012, 03:16 AM   #3
shipma3
thanks i plan on 31s so it shoudlnt be a problem then i belive its already very low gear as it has a heck of a time getting to 60 . which i could care less as it will be an offroader. probably upgrade to a np205 when i can
Old 03-10-2012, 11:36 AM   #4
odog
odog's Avatar
like what was already said, the 12 bolt is a c clip axle, so you may carry a couple extra clips in the ash tray and some gear oil when you go wheeling. I had an axle walk out on me in the hills when I was coming home with a load of firewood. It would have been an eay fix if I would have had the clips then, instead it was a long walk.
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 03-10-2012, 06:49 PM   #5
Mike C
Mike C's Avatar
Seldomly does the clip break. It's the axle itself. The problem with the clip is it is at the very inner part of the axle. So when the axle breaks between the clip and the wheel, the axle slides out of the housing.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
