Old 03-11-2012, 05:18 PM   #1
C15_Sierra
C15_Sierra's Avatar
Lightbulb Which water pump to use
I have to replace the water pump on my 5.3 swap. I know some parts you go with OEM, with other it doesn't matter. So my question to you guys is, what is your preferred brand of w/pump?
Should I order a Delco one from RockAuto or pick up a generic one from NAPA?
-Steve
1980 GMC C15 Sierra LWB
Dark Carmine Red/Carmine Int
Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011)
Now: 5.3/4L60E, 2.73 12-bolt open rear
C15_Sierra is offline   Reply With Quote
Old 03-11-2012, 09:07 PM   #2
clinebarger
Re: Which water pump to use
I would run a Delco, But they are not hard to change & I havent had any problems out of NEW aftermarket water pumps. Stay away from reman pumps.
Ive only seen 1 or 2 of these pumps go bad (leaking from the weep hole/bushing failure). But have replaced to many water pump to block gaskets to count. Check it out, Gaskets are cheap.
clinebarger is offline   Reply With Quote
