![]() Join Date: Aug 2001
BB Radiator Shroud ?
Is there suppose to be a gap between the shroud and radiator?
Thanks,
DREW67 Last edited by DREW67; 03-12-2012 at 09:24 PM. |
Ideally, there is not supposed to a gap at all, but on most aftermarket fan shrouds there are. Mine had a very small gap of like 1/16th of an inch from the shroud to the radiator. However, there is another gap that is after the shroud and radiator that is just a stock gap. I did not like either one, so I picked up some self adheasive rubberized felt at Home Creepo and solved the problem. See Photo:
#3 | |
Re: BB Radiator Shroud ?
DREW67 |
Does look like an aftermarket...but hard to tell from the photo. Something does not look quite right with the upper mounts on the shroud. From the photo the holddowns look correct. Did you try turning the shroud 180...I don't know if that would make a difference or not.
This is a big block shroud, yours look to be for a V8
DREW67 |
yep...350 c.i.d. with a 4 core radiator.
Just like to part out trucks!!
Andrew, you need a 4 core radiator to mount your shroud to.
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
You have a aftermarket 2 or 3 core radiator, BB's came with 4 core radiators, with 4 core holders
I thought that is what I purchased. I guess I will be taking it back.
DREW67 |
![]() Join Date: Nov 2007
That looks like a 2 row. If you take the cap off and look inside you can count the rows. Tell them you want the other half of your radiator.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
Got the 4 core in fits alot better.
Thanks For the Help.
DREW67 |
