C/10 junkie
I6 zbar in a V8??
I am wanting to know if my manual trans z bar and linkage from my 292 will fit on the 327 I'm going to install or do I need to get a v8 set up. Any help would be greatly appreciated
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
Re: I6 zbar in a V8??
...the 6 cylinder z-bar is to wide and the clutch rod is different to...you can do some fabbing to make them work with some cutting and welding if you can't find any...
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
C/10 junkie
Welding and cutting I can do. Just wanted to know up front what I need to make the swap go smoothly. Thank you.
C/10 junkie
How about the piece that bolts onto the block?
..don't remember for sure which one I used ...but I can get you a measurement on the v8 z-bar this weekend if that would help.
...this is the bracket I had to build for mine..gm was nice enough to do away with the second bolt hole when they went to passenger side dipstick... Posted via Mobile Device Posted via Mobile Device
this may help if you have the right holes in the block-look for my replies to this thread
http://67-72chevytrucks.com/vboard/s...d.php?t=500246 if your block doesn't have the holes,mooneyes bracket above looks easy enough to make. good luck
1969 stepside-305/4spd/12 bolt posi http://67-72chevytrucks.com/vboard/s...d.php?t=477157 1968 pontiac lemans convertible-350/pwrglde/10 bolt 1934 oldsmobile sedan-350/350/12 bolt posi 1930 model a pickup-350/350/jag ind 1928 model a roadster-283/350/9" |
C/10 junkie
Cool thanks guys. I'll have to look at the side of my block and see if the holes are there.
![]() Join Date: Nov 2008
the z bar from my 6292 bolted right up to my 350 no problem...
C/10 junkie
Thanks Kevin thats what I was wanting to hear.
![]() Posted via Mobile Device
