Old 03-14-2012, 05:05 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
87 Fuel Sending unit
I installed an 87 tank and sending unit in my 85 for the LS swap and I have 3 lines. I need to know what I do with the middle line, I have the feed and return hooked up I just need to figure something out with the 3rd line.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 03-14-2012, 05:20 PM   #2
jhngardner367
jhngardner367's Avatar
Re: 87 Fuel Sending unit
I believe that's the vent line,and if you have fuel-injection it will have to be soldered/welded shut.
If its carburretted,just run it to a vent valve,or the fuel cannister(better).
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 03-14-2012, 05:24 PM   #3
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Shouldn't it be the vent to the charcoal canister?
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 03-14-2012, 05:29 PM   #4
jhngardner367
Yeah,that's what I mean.The black plastic one that we all catch on,once in a while!LOL!
There should already be a line for it.
Old 03-14-2012, 07:23 PM   #5
softballnrd27
That thing is long gone. Can I plug it with some rubber hose and fuel injection clamps?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 03-14-2012, 07:55 PM   #6
jhngardner367
Yes,if it has a carb.But,you should then find a vented cap,or it may cause pressure in the line,and flood the carb,especially on warm days.That's what the charcoal cannister is for...to store fumes/vapor,until the engine runs again,at which time they are routed to the carb,to burn.
Old 03-14-2012, 10:35 PM   #7
softballnrd27
I will be fuel injected. 2002 lq4 fyi
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 03-15-2012, 11:40 AM   #8
rfmaster
rfmaster's Avatar
See if a stock LQ4 (donor) uses CCP canister. If it does than set it up to use purge line (evap)
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
