Old 03-16-2012, 06:14 PM   #1
jbwolfe
1971 Chevy C20 Trailing Arm Suspension
Hi all, this is my first post to this site, I've been reading different threads for a few days, and really like the site, and have found the threads very helpful.
I have a 1971 Chevy CST/20 3/4 ton pickup with trailing arm coil spring suspension in the rear. About three months ago, after hauling a large load of firewood, the trailing arms broke near clean off near the springs. I've attached pictures of the suspension.
So I want to fix the truck as cheaply as possible. I've been calling junk yards in the area, but no one seems to have the trailing arms. They all seem to have leaf springs though. Would it be possible to replace the coil spring suspension with leaf springs?
I found after market trailing arms online, they are quite a bit cheaper than LMC, anyone have any input on these:
http://www.carpartsdiscount.com/auto...ml?3593=128189
I would really appreciate some input on this. This is my first Chevy, I love this truck, and I really want to keep it!
Thanks in advance!
jbwolfe is offline   Reply With Quote
Old 03-16-2012, 07:02 PM   #2
black_sheep454
Re: 1971 Chevy C20 Trailing Arm Suspension
That sucks. Try looking through the for sale ads on here for one or become a supporting member and post a want to buy ad.
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 03-16-2012, 07:41 PM   #3
Sicklajoie
The Niner
Sicklajoie's Avatar
This is for a pair:
http://www.manestruckparts.com/store...&Category_ID=6
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 03-16-2012, 11:41 PM   #4
jbwolfe
Originally Posted by notsolo View Post
Nice used trailing arms show up here or on Ebay from time to time, I found a nice set of 3/4 ton from California a few years ago came off a 1964 3/4 ton....The difference between 1/2 and 3/4 ton is a flat strap welded top and bottom to reinforce for heavier load.
If I were to find a pair of 1/2 ton trailing arms, would I be able to weld on a similar metal plate for re-enforcement?
Originally Posted by Sicklajoie View Post
That looks like a good price, I will definitely bookmark that site.
Does anyone have any thoughts about the idea of replacing the current suspension with leaf springs? A couple junk yards in the area have sets of leaf springs for under $100.
What exactly does it mean to become a supporting member?
Old 03-16-2012, 07:47 PM   #5
notsolo
notsolo's Avatar
Thanks in advance!
notsolo is offline   Reply With Quote
Old 03-21-2014, 04:54 PM   #6
gale
May depend on the year. My '67 C20 has a formed steel channel on both sides of each trailing arm. The two halves plus the two reinforcement channels are riveted together.
I bought a pair on this list and they look good but shipping will kill you.
The placement of the reinforcement from the factory surprises me because midspan is not where they usually give up.
Before I ran across the pair on this site I had planned to fabricate them from 3" channel (C3x4.1) but that is quite a bit of work.
Gale Gorman
'54 3100
'67 C20 stepside
gale is offline   Reply With Quote
Old 03-16-2012, 11:49 PM   #7
black_sheep454
It cost $25 per year to become a supporting member. It allows you to post for sale and want to buy ads. Supporting members like myself have blue names instead of pink.
Old 03-16-2012, 11:57 PM   #8
desertnick69
desertnick69's Avatar
Hello i have a 1969 C-20 that has been in the family for 42 yr got totaled last April it has good trailing arms if interested let me know
desertnick69 is offline   Reply With Quote
Old 03-17-2012, 12:03 AM   #9
Indyuke
I notice you're up north of Bellingham. There is a really good yard in Arlington, about 65 miles south of you. I was there last week and noticed they had two of our trucks each with trailing arm suspension intact. There's another sister yard in Lynnwood about 80 miles from you that currently has four of our trucks. You might give them a try.
Indyuke is offline   Reply With Quote
Old 03-17-2012, 02:10 AM   #10
jbwolfe
I will keep it in mind, and let you know what I decide.
You don't happen to remember the names of the scrap yards do you? That would be great to find them locally!
Old 03-17-2012, 09:37 AM   #11
Sequoyah
so easy a caveman can do it...
Sequoyah's Avatar
Looks like it was due to rust? I don't have anything for sale, but I have a 1/2 ton and welded some flat stock to the top and bottom before I even knew about this. It just seemed like the thing to do to make it stronger.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=242380
Sequoyah is offline   Reply With Quote
Old 03-17-2012, 12:42 PM   #12
Indyuke
They're called Pick N Pull.
http://www.picknpull.com/locations.aspx
Old 03-17-2012, 08:59 PM   #13
jbwolfe
Yeah it was rust. This truck started life in a more salty environment. The whole truck is pretty rusty, the rocker panels are nearly completely missing on one side. I think when I get new trailing arms, I'm going to re-enforce them, sand them down and paint them.
Cool! If I don't find a pair close to home, I will definitely check them out.
Old 03-18-2012, 04:34 PM   #14
68 TT
Still plays with trucks
68 TT's Avatar
Here are some pics of the 3/4-ton arms I was going to put on my stepside. A little dirty but in pretty good shape.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 03-22-2012, 02:42 PM   #15
jbwolfe
Well I think I'm going to find a good condition pair of 3/4 trailing arms and just replace the ones I have. Any words of wisdom as far as actually replacing them?
Old 03-22-2012, 04:29 PM   #16
k2rm
k2rm's Avatar
Mine were almost that bad when I replaced them. Here are some tips.
Replace the trailing arms one at a time.
Detach the ebrake cable from the trailing arm.
Jack up the truck with the jack under the axle. Once it gets high enough, place a jackstand under the frame on both sides and remove the wheel. Slowly lower the axle until the spring is relaxed and place a jackstand under the the axle
You won't beable to remove the bolt holding the retainer cup to the lower part of the coil to the arm. The rust will have completely fused the bolt to the trailing arm. Hopefully you won't have an issue on the upper retainer cups so just loosen the upper retaining cups.
Remove the pivot bolt at the cross member and remove the trailing arm with the spring still attached. A big breaker bar comes in handy here.
Cut the retaining cup so you can remove the spring. You will need to find some new retaining cups. ECE and others sell them.
When reinstalling, I first attached the trailing arm to the cross member and then attached the coils.
k2rm is offline   Reply With Quote
Old 03-22-2012, 06:05 PM   #17
Shaky
Six in a row makes it go...
Shaky's Avatar
Mine were starting to go that way. It may have made more sense to look for replacements, but here's what I ended up doing:
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 03-22-2012, 11:11 PM   #18
Sequoyah
Sequoyah's Avatar
You can see what I did (or rather have my friend who can weld do) lol
My build thread
Old 03-23-2012, 12:57 AM   #19
jbwolfe
What about the shocks?
I'm strongly considering doing some re-enforcements on my new trailing arms.
The arms I'm getting are 3/4 ton arms, so they have the metal strip running along the top and bottom, preventing splitting. I'm not sure from your picture, but did you also add metal strips along the sides of the arms? I was thinking about doing that as well.
Old 03-23-2012, 10:19 AM   #20
Sequoyah
Sequoyah's Avatar
No, just strips on the top and bottom.
My build thread
Old 03-23-2012, 10:27 AM   #21
k2rm
k2rm's Avatar
Yup, forgot about the shocks and u-bolts. The shocks can be removed once the suspension is relaxes.
On mine, I was able to remove the u-bolt nuts and the lower shock mounting plate, but the shafts were also rusted to the trailing arm. So, I had to cut the u-bolts above the axle.
Old 03-27-2012, 10:13 PM   #22
jbwolfe
Thanks for all the help everybody! I've found a set of 3/4 ton trailing arms, just have to get them shipped to my house. A friend of mine who is a mechanic is going to help me replace them. I'll be sure to post updates on how its going.
Anyone have any recommendation on a good paint to use on the new trailing arms once I take a wire brush to them?
Old 03-28-2012, 05:51 AM   #23
gysgtc
POR-15 to paint them with. The stuff is as hard as beavers teeth.
gysgtc is offline   Reply With Quote
Old 04-13-2012, 10:26 PM   #24
jbwolfe
Well I got my new trailing arms today! They are 3/4 trailing arms, great shape, just need cleaned up and painted.
Heres my question: the 3/4 ton trailing arms have the metal re-enforcement strip spot welded to them. I'm thinking about having a friend with an arc welder weld the strips of metal solid all the way around. Does that sound like a good idea?
Old 04-14-2012, 02:33 AM   #25
chopped68
that is what I did with mine.the trailing arms had the plates spot welded on but I took them off to make sure they had no heavy rust underneath the plates,welded the 2 halves together and plated them all the way around with 12 gauge steel.I also z'd them 3 inches at the axle pad.
ken
chopped68 is offline   Reply With Quote
