Old 03-18-2012, 01:22 AM   #1
MikeJones16
MikeJones16's Avatar
Chart concerning tires and rpm?
I'm wondering what gears i want to put in my one tons. Planning on putting lockers front and back. Tranny is a th350 with a np205. I know there is a chart somewhere but i can't find it. Thanks
MikeJones16 is offline   Reply With Quote
Old 03-18-2012, 04:57 AM   #2
MTCK
MTCK's Avatar
Re: Chart concerning tires and rpm?
http://www.ringpinion.com/Calculators/Calc_RPM.aspx
Good starting place...
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 03-18-2012, 10:11 AM   #3
rocket20
pittbull tire has rpm, mph, tire size, plus more charts
rocket20 is offline   Reply With Quote
Old 03-18-2012, 01:34 PM   #4
MikeJones16
Months ago someone posted a link that all you had to do was select your tranny. engine size and tire size and it was a chart of where your rpm's would be at so you can figure out the gear ratio you'd want
Old 03-18-2012, 05:17 PM   #5
MTCK
MTCK's Avatar
If you have a TH350 it is a direct drive in 3rd gear. Use the calculator on the randy's R&P page and you can see what rpm you'll be at in what gear. If it has a lockup TC, the rpm's will be in the "manual" window. If non-lockup it will be the same as the "auto" window. Not much difference either way. Sorry I haven't seen the chart you reference. A lot of gear selection has to do with how you will use the rig...
-Marcus
Project Plow Truck
Old 03-19-2012, 01:45 AM   #6
MikeJones16
Looks like i'll be going with 4:88s
it seems with the 39.5" tire at 70mph(110kmh) puts me at just under 3k
And the truck doesn't see highway. for very long anyways.
Old 04-12-2012, 12:56 AM   #7
1malo68
1malo68's Avatar
Everything you could possibly want to know is here.
http://www.grimmjeeper.com/gears.html
1968 K10/30
Frame Off Project "Overkill"
My 5 year, $30,000.00 toy
1malo68 is offline   Reply With Quote
