Old 03-19-2012, 06:09 PM   #1
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
wiring fun lol
so recently i decided to get my gauges all working so i went out and bought a oil and temp sensors. now my temp sensor worked fine but since i had my headers installed i cant hook the sensor back up in the spot as the headers are in the way.
so i went and bought a new one and installed it in the t-stat housing and when i get to operating temp its pegged at 240
and the oil press gauge stays pegged all the way to the right all the time.
any help would be great!
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 03-19-2012, 06:40 PM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: wiring fun lol
Sounds like your sensor leads are grounded out somewheres. May have to trace the wires all the way back to the fire wall to make sure they're all good. same thing under the dash too.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 03-19-2012, 09:00 PM   #3
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: wiring fun lol
was afraid of that :S
Old 03-22-2012, 10:11 AM   #4
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: wiring fun lol
now is the tan sensor lead for the oil press "hot when the ignitions on or trucks running or is it a ground?
Old 03-22-2012, 10:34 AM   #5
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: wiring fun lol
so was out tinkering with the wiring tracing things and everything keeps getting weirder (lol yes weirder!)
when i started this fun task the oil press and temp gauge were acting up (still are) the service soon light was on but would dim as you drove.
now i have cleaned the ground under the dash and traced the wires and nothing seems to be out of place so i put it all back together and the service light is out gauges still don't work and when you turn on the head lights the volt gauge drops quite a bit and when you turn the signals on the volt gauge moves with the signal click. where do i look now?
Old 03-22-2012, 11:03 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
Re: wiring fun lol
may wana make sure the cluster board is straight@turn markers etc
and the plug is in tight
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-22-2012, 11:08 AM   #7
Desert1957
Desert1957's Avatar
Re: wiring fun lol
Start checking ALL you ground wires , make sure all connections are clean and tight. look at the little wire right at the battery that goes to the fender, if it doesn't have one , make one.
Most Negative battery cables ground at the Alternator bracket, make sure bracket is tight to the engine, check for any small cable or straps at the back of the engine to the firewall. These are easily left off during an engine swap or valve cover removal.
Here is a link to an earlier post
http://67-72chevytrucks.com/vboard/s...wire+locations
Desert
Desert1957 is offline   Reply With Quote
Old 03-22-2012, 11:11 AM   #8
BLE 'BURBAN
Re: wiring fun lol
Disconnect the leads to the sending units, ground them out with the key on engine off and have some one watch the gauges. If they peg out all the way then the gauge is ok and the problem is with the sender. If not then the problem is with the gauge itself.
My battery gauge does the same thing even with a 145Amp alternator I've got. As long as it doesn't drop and stay down while running I don't worry about it.
Old 03-22-2012, 08:11 PM   #9
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: wiring fun lol
Dis connect the leads to the sending units, ground them out with the key on engine off and have some one watch the gauges. If they peg out all the way then the gauge is ok and the problem is with the sender. If not then the problem is with the gauge itself.
ok will do this tomoro and see how i make out i'm thinking that my oil press gauge is broke and my temp sensor is no good.
