frame straightening
My truck is dog tracking and everything looks good so i thing my frame is bent a bit and i wont to get it straightened.
I am going to box in my frame and i heard even if done right it can warp slightly so should i box it then have it straightened or straighten it first?
84 chevy short box 4 inch suspension lift 3 inch body lift 5.9 cummins |
Re: frame straightening
Box it first then straighten. Then check to make sure no welds gave way or anything. This is how I would do it. Another member with more knowledge than I may say different. But either way I think your frame should be straighter
Maybe go int the suspension and chassis section of the forum and ask. valuable knowlage there Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
I assume you are talking about the '85 4x4 in your signature: How do you know it's dog tracking? The front axle track width is slightly wider than the rear, giving a dog track appearance when following from behind.
Follow the truck and check down both sides before jumping to any conclusions. Then - before going to the frame shop - have the alignment checked at a shop that can give you the "rear axle thrust angle". See if that either confirms or denies your suspicions. After that - start down the path on how to fix it. My $.03 - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 03-20-2012 at 07:28 AM. |
