Old 03-20-2012, 09:40 AM   #1
aidans70
need ideas
So I am fairly new to these trucks and am looking for advice on what are good mods to do to my sons 70 gmc. I already know I want to change from drums on the front to disc's and from 6 lug to 5. what would be my easiest and cheapest options for this? I have a chance to get an 88 donor truck for the front end but what about the rear axles? also I have found a 327 for it and a turbo 400 tranny. what other ideas do you guys have?
aidans70 is offline   Reply With Quote
Old 03-20-2012, 09:44 AM   #2
71swb4x4
71swb4x4's Avatar
Re: need ideas
Drum to disc is a great one. Others are to add a front sway bar, install an internally regulated alternator instead of the original external, HEI instead of points, and do the headlight relay conversion. I am sure there are tons more, those are the ones that came to the top of my mind. They are all good practical modifications that help imrove the day-to-day drivablility of the truck. Most add a measure of safety too.
Edit:
drum to disc: http://67-72chevytrucks.com/vboard/s...d.php?t=444815
drum to disc again: http://67-72chevytrucks.com/vboard/s...ad.php?t=35042
swaybar: http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
headlight relay: http://67-72chevytrucks.com/vboard/s...d.php?t=293913
headlight relay again: http://67-72chevytrucks.com/vboard/s...d.php?t=182351
more headlight relay: http://67-72chevytrucks.com/vboard/s...ad.php?t=92228
And a great place to spend a bunch of time: http://67-72chevytrucks.com/vboard/f...play.php?f=220
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-20-2012, 10:02 AM   #3
aidans70
Re: need ideas
what about junk yards? are there any good ideas for parts from other trucks that help improve these trucks?
Old 03-20-2012, 11:27 AM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: need ideas
Sway bars,71-87 IIRC disc brakes,later engine,OD tranny core,serpentine belts systems are all good JY mods.The 88 will have different width front suspension.GM built a lot of interchangability into their vehicles so many pieces can be swapped from later trucks and even some from cars.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-20-2012, 12:28 PM   #5
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Re: need ideas
Depending on the end result desired some lowered spindles and/or springs can help handling and appearance. Relocating the fuel tank under the bed is nice. Power windows, AC and sound-proofing will improve driving comfort alot. If you and your boy aren't over 6'2" a set of 40/20/40 seats out of a 2001+ Silverado is a great improvement. Tilt column and 15" steering wheel is quick and easy. Plus all the other mods those before me have mentioned.
Really, there is a seemingly endless list of upgrades you can do either as bolt on or with some fab work to modify these trucks. It all comes down to what you want when it's all said and done and how deep them pockets of yours are!
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 03-20-2012, 12:32 PM   #6
Coley
Coley's Avatar
Smile Re: need ideas
From a drive comfort point of view, the first thing I would make sure I had in my truck was a tilt wheel.
Ever since I had one in my original/first '72....that has been the first upgrade I've put in all my trucks since, at least when they didn't have one from the factory.
Unlike a/c or other options, which I appreciate, I find I use this one every time I get behind the wheel. and always notice its advantage.
Great investment and upgrade!!!
My two bits.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
