Old 03-20-2012, 06:14 PM   #1
PaRedneckRiders
Frame paint?
Just got my frame pretty much all stripped down and im looking for a good paint, but not sure what to use.
Its going on a 4x4 k10 frame that will be in the mud and woods alot but i want something that will hold up decently to some abuse.
I was thinking get the frame sandblasted and primed then use POR-15, but it says to just clean the frame and apply directly to the rust.
Ive also heard of some people using a tractor implement paint but im not sure how well that would hold up, i just need some opinions on what i should use.
PaRedneckRiders is offline   Reply With Quote
Old 03-20-2012, 07:05 PM   #2
Goldfinger
Goldfinger's Avatar
Re: Frame paint?
I like the duplicolor caliper paint. its a pretty hardy paint.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 03-20-2012, 09:16 PM   #3
79k30dually
Re: Frame paint?
Read the chemicals in the paint. ISOCYANATES(sp) are BAD news. Gloves and a GOOD quality respirator are a must. Good luck, Ron
79k30dually is offline   Reply With Quote
Old 03-20-2012, 09:37 PM   #4
notallthere
Re: Frame paint?
POR 15 works great just follow the instructions to a tee. Knock the loose rust off then use the cleaner, prep and paint.
Chassis Saver is the stuff that I use now. Less prep and harder paint.
http://www.magnetpaints.com/underbody.asp
notallthere is offline   Reply With Quote
Old 03-20-2012, 10:27 PM   #5
AntiGov
AntiGov's Avatar
Re: Frame paint?
i used RUST BULLET as first coat and rustolem black satin as top coat...the specs on rust bullet are impresive and require little prep. the rust bullet does not require a top coat to be uv resistant like por15 does, but is silver in color so i went with black satin top coat and i can rattle can any needed touch up or small parts along the way. from what i gather the por15 requires exstensive prep or failure may occur and will fade as it is not uv resistant, so u would have to top coat anyways..........just my 2 cents....others may know different...........
88 3+3 454 400 205 410 drw to srw still in pieces
90 3+3 350 400 205 410 srw
84 1/2 ton lb 6.2 4x4 parts truck
AntiGov is offline   Reply With Quote
Old 03-20-2012, 11:06 PM   #6
hillbilly hauler
Re: Frame paint?
i have been using spray on bedliner from a can at oreilly. it looks good, sprays nice and lays nice. i have it on everything from inner fenders to frame to rear end
hillbilly hauler is offline   Reply With Quote
Old 03-21-2012, 12:28 AM   #7
FlossyB
Re: Frame paint?
My uncle is restoring his 76 C10. He used http://www.kbs-coatings.com
He said the stuff sprays beautiful.
FlossyB is offline   Reply With Quote
Old 03-22-2012, 11:08 PM   #8
badpontiacs
badpontiacs's Avatar
Re: Frame paint?
Awesome stuff here, you can brush is on and it lays out flat (no brush strokes) when it drys.
badpontiacs is offline   Reply With Quote
Old 03-23-2012, 09:35 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Frame paint?
What did you use it on, your 68 c10 short step? You have in pics of how it looks?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-21-2012, 12:29 AM   #10
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Frame paint?
Ditch the POR15. Use ZeroRust. Works way better. I like it.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 03-21-2012, 06:40 AM   #11
PaRedneckRiders
Re: Frame paint?
so with most of these products i should not get my frame blasted, How do u think the paint would stick because the front of my frame (back cab mounts forward) still has paint on it, not sure if its factory or not i think it might be.
Old 03-21-2012, 12:08 PM   #12
Weasel Diesel
Re: Frame paint?
Eastwood Xtreme Chassis Black worked great for me.
Weasel Diesel is offline   Reply With Quote
Old 03-21-2012, 02:41 PM   #13
ChevyMutt
ChevyMutt's Avatar
Re: Frame paint?
I sandblasted my frame & shot it (along with tranny & t-case) with spray on under coating from Auto Zone. We used 2 cases on the frame, tranny, t-case and bottom of the cab, which cost right around $150.
79-87 3/4T Plow Truck. Running Gear all 79, body is 84-87.
Originally built by my Dad & Brother in late 90's early 00's. I bought the truck in summer of 11; dad & brother put new box sides on, and surprised me with a new paint job. Jan of 12 the float stuck in the carb and she burned... The truck is back in MI now and being re-built AGAIN by my Dad & Brother.
http://67-72chevytrucks.com/gallery/...8633&protype=1
ChevyMutt is offline   Reply With Quote
Old 03-21-2012, 05:11 PM   #14
85gmcguy
Plays with trucks
85gmcguy's Avatar
Re: Frame paint?
I like the Eastwood products myself- Rust Encapsulator, Chassis Black, Underhood Black. They've always worked well for me.
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 03-21-2012, 06:31 PM   #15
nekkidhillbilly
Re: Frame paint?
i used kbs on my 66 skylark frame works great however i never topcoated it and it needs redone. topcoated it works awesome.
nekkidhillbilly is offline   Reply With Quote
Old 03-22-2012, 06:56 AM   #16
PaRedneckRiders
Re: Frame paint?
Ok been looking around a little more and im starting to like this stuff, correct me if im wrong but from what i read you can spray this primer on clean bare metal, idk about spraying on rust though. http://www.eastwood.com/ew-extreme-c...er-quarts.html
And then using this http://www.eastwood.com/ew-extreme-c...-satin-qt.html
Old 03-22-2012, 12:56 PM   #17
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Frame paint?
What about glyptol? Anybody use that old school trick anymore?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-22-2012, 07:20 PM   #18
85gmcguy
Plays with trucks
85gmcguy's Avatar
Re: Frame paint?
That's how I understand the instructions on the extreme primer, too. I've not used it but I have sprayed the chassis black over the Rust Encapsulator, I use it a lot for primer.
Gary
My Dad's Old Truck
1985
