Old 03-20-2012, 10:44 PM   #1
ooimpalaoo
ooimpalaoo's Avatar
spindles on the way what more do i need?
ok i have a set of 2.5inch drop spindles on the way what more do i need to swap my 69lwb over can i use the booster from a 71 that i have and the prop valve? was thinking i would buy the calipers used what years will work? any advice?this is my DD i dont want lots of down time....thanx
ooimpalaoo is offline   Reply With Quote
Old 03-20-2012, 10:44 PM   #2
ooimpalaoo
ooimpalaoo's Avatar
Re: spindles on the way what more do i need?
oh and will i have any problems with 15" steel wheels and the drop spindles?
Old 03-20-2012, 10:47 PM   #3
Pro Performance
Pro Performance's Avatar
No, 15" wheels should be Ok, unless they have a ton of backspace. I had 15" wheels on my old truck with a 3" drop spindle.
What kind of calipers are you looking for? Just replacement ones? I think you can buy rebuilt ones from the auto parts store for a very reasonable price.
Pro Performance is offline   Reply With Quote
Old 03-20-2012, 10:59 PM   #4
SCOTI
SCOTI's Avatar
Agreed. Are you pulling some calipers off of a currently running truck? If not, I would use them as the cores for some fresh parts house rebuilt units.
The 71 master cyl, booster, & prop valve will work for you.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-20-2012, 11:21 PM   #5
ooimpalaoo
ooimpalaoo's Avatar
so do i use my stock A arms ?
Old 03-20-2012, 11:23 PM   #6
Pro Performance
Yeah, your stock a-arms will be fine.
Old 03-20-2012, 11:58 PM   #7
ooimpalaoo
ooimpalaoo's Avatar
so the spindles i get i get for a 69?
Old 03-21-2012, 12:18 AM   #8
SCOTI
SCOTI's Avatar
You're contradicting yourself.... Do you have spindles on the way or not? If so, what did you buy them for (a 69 or what??)?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-21-2012, 12:45 AM   #9
ooimpalaoo
ooimpalaoo's Avatar
no sorry i mean im going to order them in the morning and yes right now my 69gmc is 6 bolt drums all around i have the 5 bolt rear out of the 71
Old 03-21-2012, 12:01 AM   #10
Pro Performance
Yes, the spindles will be the same across the board. What kind of truck do you have now? a 69 lwb, correct? And you just want to use the booster and brakes off a 71? If so, It will all work together.
Just make sure to get 71 brakes etc., because your spindle will be for a disc brake truck. THen just get all the brakes for a 71 chevy, which will be 5x5 bolt pattern (5 lug).
If you have 6 lug now, then you will have to convert the back. This is the way I understand it, as I don't believe they made a 6 lug disc brake, only drum.
Old 03-21-2012, 12:46 AM   #11
ooimpalaoo
ooimpalaoo's Avatar
im thinking about the CCP spindles they ok?
Old 03-21-2012, 08:23 AM   #12
SCOTI
SCOTI's Avatar
http://67-72chevytrucks.com/vboard/s...68#post4462868
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-21-2012, 10:14 AM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
Look at Summit Racing for CPP spindles.
Buy them for the 63-70 application and you will be fine.
Here's your choices from Summit Racing,...
http://www.summitracing.com/search/Y...rd=c10+spindle
Keith
Convert to disc brakes.
Old 03-21-2012, 11:47 AM   #14
Pro Performance
Very good info on Drum to Disc conversion!
If you go with the CPP Modular spindle, it will leave the option for a big brake system down the road, like Baer or Wilwood. If that isn't in the plans, then any other the other will be good. I used the McGhauhys drop spindle.
Let me know if you need spindles still, and I would be glad to help you out.
Travis
Old 03-21-2012, 12:45 PM   #15
ooimpalaoo
ooimpalaoo's Avatar
yes i still need spindles they will cost me 334$ all said and done to get them to canada so if you can do better then that ill grab them off you ...also i was just outside looking at the c10 that i thought was a 71 and its not (drums in the front) so what other year booster will work for me? thanx again and again
Old 03-21-2012, 01:51 PM   #16
SCOTI
SCOTI's Avatar
71-72 are the easiest to swap.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-21-2012, 02:24 PM   #17
cdowns
cdowns's Avatar
to get used calipers makes no sense as they are quite cheap at any autoparts store
to go thru the work of installing new spindles and use 40year old balljoints and tyrod ends??
Old 03-21-2012, 04:07 PM   #18
ooimpalaoo
ooimpalaoo's Avatar
yes im going to get all new parts now i agree...i have a 1971 chevy 4x4 that i wont be using for another year so im going to take the booster and prop valve off it in the meen time will i have to change the rod on it ?
Old 03-22-2012, 12:14 PM   #19
ooimpalaoo
ooimpalaoo's Avatar
the other c10 that i thought was a 71 i guess is a 70 and its just a frame and cab so im going to try and Z it just for fun..i also want to try to cup a set of lower A arms so im guessing that if all goes well and i want to use them on my 69 with the spindles i get i should cup the 70 lower arms right? if you dont get all this i have my DD 69c10/my 4x4 71c20/frame and cab in yard 70c10/and then a set of 71c10 running gear..5 bolt front/rear.
