03-22-2012, 05:16 PM | #1 |
another stupid question???
I have 350thm mated with 250 inline6. There a cable coming out of the transmission. How do I hook it up to the engine??? Don't know what the cable is for and my one barral carburator does not have a connection for this cable. I am guessing the transmission is from the 80's and inline6 is from 1975. Please help!!!!
03-22-2012, 05:27 PM | #2 |
Re: another stupid question???
Well Gabe....
I'm thinkin that cable would be for your kick-down function...from 3rd to second....for passing gear. If the end of it is plastic and it looks like it fits into a 3/4" (give-er-take) square anchor....and the cable end is a long slotted steel hooper.....then that is what it is. After you verify that that's what it is....then we'll help you figure out how to connect it... Should be a piece of cake.
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
03-22-2012, 09:24 PM | #3 |
I have the same thing,the kickdown is not hooked up,but runs fine.I have only driven around the neighborhood though,was wondering how to hook it up.Thanks.
03-22-2012, 09:41 PM | #4 |
without it, you will be sorely disappointed when you go to pass someone on the highway... Not hooking it up also affects upshifts - what might feel "cool" might be damaging your trans. The jury still seems a bit split on this point. I'm oblivious, I have a manual trans
These might help a bit: http://www.race-dezert.com/forum/sho...chment-to-carb http://www.justanswer.com/chevy/1gin...down-fule.html http://www.chevytalk.org/fusionbb/sh...hp?tid/239594/ |
03-23-2012, 05:16 PM | #5 |
a thousands thanks. people still care about us sixer(inline6) engine!!!
03-24-2012, 12:04 AM | #6 | |
I think I have a base plate bracket or two(that's what you'll need to mount the fixed end to) and I'll at least take a pic of that so you'll know what yer lookin for. In fact, Gabe, I have a feeling that Mr. Gskt. makes a few universal brackets that mount from on just about anything from the valve cover to the base-plate. You might get lucky down at O'Reilleys. I'll try to follow up tomorrow. Rodger on the six cylinder lovin'.
03-24-2012, 01:42 PM | #7 |
I know I need a bracket to hold the square piece of the cable but what about the carb linkage. How does that looks like???
03-28-2012, 01:32 PM | #8 |
any pictures anybody?
03-28-2012, 02:18 PM | #9 |
Senior Enthusiast
Regardless of which bracket is used, the square hole with the notch shown in these photos is what the mounting point looks like for the kick down cable at the engine end:
The carb connection is normally either a ball stud or a pin type for a circlip or a small cotter pin. Most kick down cables have a larger round hole at one end of the slot to fit over the ball or head. Here are some examples:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
03-28-2012, 02:54 PM | #10 |
Nice work Mark.
Gabe, The second example that Mark has posted of the ball/knob-studs is the most common of the GM OE linkage anchors.
03-28-2012, 05:14 PM | #11 |
wow. it's that simply. the 3rd pic is for both gas cable pedal and kick down cable. I'll look it up to buy it. thx
03-29-2012, 12:03 AM | #12 |
Gabe...
Some applications used a third cable or chain assembly....the third for cruise control.
