Old 03-22-2012, 11:05 PM   #1
JCs72C10
Key sticks when starting...
Title says it all.
There is resistance when turning to key to crank the truck and the key sticks once it hits the start position and I have manually turn the key back (it doesn't spring back at all).
I just replaced the key cylinder. The only other thing I can think of is the actuator rack and/or rod...
Any input would be greatly appreciated!
JCs72C10 is offline   Reply With Quote
Old 03-23-2012, 03:08 AM   #2
kylep
kylep's Avatar
Re: Key sticks when starting...
this happened to me the other day, except my key would not move at all. i jacked up the front of the truck enough to get the tires off the ground then lowered it then it worked.
if it aint that i dunno, maybe the ignition?
kylep is offline   Reply With Quote
Old 03-23-2012, 03:51 PM   #3
JCs72C10
Well... my truck is and has been on a lift for about a month, lol! It has to be something withing the column itself. Guess this weekend will consist of a self taught column rebuild! We'll see what happens...
Old 03-23-2012, 04:22 PM   #4
naphtali5725
naphtali5725's Avatar
Originally Posted by JCs72C10 View Post
Title says it all.
perhaps the ignition switch the actuator rod operates is causing it?
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 03-23-2012, 08:35 PM   #5
Goldfinger
Goldfinger's Avatar
the actuator is gone. Not 100% sure how to fix it but on my ford i was told i needed a new column to get the pieces. So i just turned it into a keyless ignition.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 03-23-2012, 09:52 PM   #6
JCs72C10
I'm thinking it's the actuator as well... not sure if it's the rack or rod though. There is a kit available that has both.
A key-less ignition might be another way to go... appreciate the idea--it hadn't even occur to me
